96 Outback heated seats???
8 replies to this topic
#1 teppichkopf
teppichkopf
    USMB is life!
  • 165 posts
  • Seattle
Posted 25 November 2005 - 06:37 PM
Just bought a 96 OBW. It has the switches for heated seats. During the test drive I didn't seem to notice if they heated up. (The light indicator light didn't go on.)
My question is: Did the switches come in all models regardless of if they had seats?? Or only with models equiped with the heated seats??
#2 Handtool
Handtool
    Eat, Live, Breath Subaru
  • 292 posts
  • Yelm
Posted 25 November 2005 - 07:20 PM
If you have switches I would assume you have heaters. I would check for blown fuses. I believe the heaters are tied into the cigar lighter? I also recall a couple of instances of wiring for the vanity mirror lights shorting out and causing the the heated seats to quit working.
#3 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 25 November 2005 - 07:49 PM
It is possibile that the indicator lights are blown. how long of a test drive did u go on? press the button down for "high" setting, then give it a couple minutes, I had a hard time noticing that the seat was on, the first couple times, but it was on 'low' unknown to me.
#4 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 25 November 2005 - 08:06 PM
Only models with the cold weather package have the switches. This also gives you heated side mirrors, and block heater. In 97 subaru also added heated windshield.
Like others have said, I would check the fuse first.
#5 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 25 November 2005 - 09:10 PM
i have heated seats, and it takes them some time to warm up. A test drive may not be enough time to let them warm up. The fact the switches didnt light up justmeans, a classic subaru thing, the bulbe are burned out.
nipper
#6 later, Peter
later, Peter
    USMB is life!
  • 218 posts
  • Pacific North West
Posted 25 November 2005 - 11:08 PM
Block Heater???
I have a block heater?
where's the plug?
Later,
Peter
#7 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 25 November 2005 - 11:10 PM
look under the front bumper at the license plate .. i think the plug is to the left of it ..or maybe right .. its very obvious once you look for it
nipper
#8 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 26 November 2005 - 12:25 AM
nipper
If you are looking at the front it is on the right side.
#9 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 26 November 2005 - 02:24 AM
I don't have the proper wiring diagrams to look at, so this is just a best guess.
If a fuse is blown for the switch lights, you'd notice other lights not being on.
The heaters are most probably turned on with a relay, becuase small switch contacts can't handle the amperage the heaters draw. It is possible the indicator lights are tied to the relay contacts as well, and won't light if the relay doesn't energize.
