drive axle question
4 replies to this topic
#1 86subaru
86subaru
    Elite Master of the Subaru
  • 3,052 posts
  • ohio
Posted 03 October 2003 - 05:58 AM
ok i my be buying a full time 4wd a/t gl-10 wagon w/82,000 mi , the outer cv boots are ripped on the front , can you just replace the boots or should i replace the whole drive axle ?? no noise yet , and it is a turbo , :wave:
#2 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 03 October 2003 - 07:56 AM
Just replace the whole thing. Since it's a turbo A/T the axles for nonturbos will fit it.
#3 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 03 October 2003 - 08:14 AM
*If* they are the original axles and aren't making noise, it *may* be worth re-packing and re-booting. Aftermarket axles generally suck.
#4 86subaru
86subaru
  • 3,052 posts
  • ohio
Posted 03 October 2003 - 10:55 AM
they are original axles , thanks
#5 MilesFox
MilesFox
    Catch this Fox!
  • 9,117 posts
  • Madison/Milwaukee, WI
Posted 03 October 2003 - 06:43 PM
jim, i would go ahead and get new boots, they have the split type, but get the OE type boots(which require disassembly of the axle to replace). you already have molybendum grease, so if you get the boots, i can rebuild them for you.
i was going to do the same on my axle on my turbo wagon, rather than the split clamp on boots.
my axle didnt make noise, but now its pulling since i got stuck in some mud. i need to take it apart and clean it out before it damages, but if i do that now it will be ok
since its not making noise, you it would last as long if not longer than aftermarket axles(and cheaper, too!) as long as you dont drive the hell iout of them before you get them fixed!
