Scalloped tire wear, what to do?
9 replies to this topic
#1 soobyfan
soobyfan
    USMB Regular
  • PipPipPip
  • 45 posts
  • Beaverton, OR
Posted 01 December 2005 - 11:47 PM
I have a '96 OBW, 2.2L, 5 sp manual transmission. I recently put on my snow tires for the winter and found my right rear tire had excessive wear on the inside edge. The wear was uneven, and on only about 1/3 of the circumference of the tire. The wear was so bad the ply's are showing.
I have been reading the threads on the viscous coupling and am worried this may be the cause. I should also mention I am not noticing binding when in tight turns. Note: The car is new to me, I do not know if all 4 tires were within 1/4" in circumference.
1. How can I functionally check the viscous coupling?
2. If the VC is bad can I drive it for a couple of weeks without ruining my snow tires?
3. Any other ideas on what to look for?
#2 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,851 posts
  • Texas
Posted 02 December 2005 - 08:10 AM
I think scalloped wear is most commonly associated with out-of-balance wheels and/or weak strut issues. I'd try to confirm the wheel hasn't thrown a weight and is true and balanced. The car is old enough it seems to possibly have a bad strut as well, so see if that corner seems 'bouncy' or has other problems.
#3 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 02 December 2005 - 08:37 AM
Yea, second vote for the strut.
#4 Strakes
Strakes
    Kaboom? Kaboom?
  • 520 posts
  • Knoxville
Posted 02 December 2005 - 10:11 AM
Check the balance and then the strut. My wife's 93 chewed through set of tires because the struts were bad. If it's the strut...try and replace all 4 at the same time and get an alignment too.
#5 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 02 December 2005 - 12:27 PM
i vote for a bad strut, bad wheel alignmnet, or bad bushing in the rear.
Do a search on torque bind, if you had it you would know it.
nipper
#6 soobyfan
soobyfan
    USMB Regular
  • PipPipPip
  • 45 posts
  • Beaverton, OR
Posted 03 December 2005 - 12:17 AM
Thanks for the input, I appreciate it.
#7 soobyfan
soobyfan
    USMB Regular
  • PipPipPip
  • 45 posts
  • Beaverton, OR
Posted 03 December 2005 - 01:44 PM
Nipper,
When you refer to a bushing for the rear strut are you talking about the bushing in the strut mount?
Thanks.
#8 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 03 December 2005 - 01:59 PM
Sure could be the strut, but the fact that its not all the way around the tire makes me think its an unbalanced or bent wheel. Could also just be a bum tire, I've had tires damaged from an impact that didn't blow at the time, but failed just as you described months later.
Gary
#9 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 04 December 2005 - 12:09 PM
yeah, i'm sure it's not that big a deal.
get some new rubbers, keep then balanced, get an alignment, and keep them rotated
#10 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 04 December 2005 - 02:27 PM
Nipper,
Thanks.
could be a bushing not in the strut, but on one of the control arms .. just something else to look at, as i like to list all the possabilities.
nipper
