Reviving '80 brat (still)
So, as some may remember, I got an '80 brat with a toasted engine, but a doner 1300 to go with..
http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=2476
The car sat for 10 years in a field and I got it free :)
As my summer project, I've pulled, checked replaced all brakes, pulled and pressure tested the gas tank, pulled the engine and dropped the doner engine (i think a '78 1300). The block was different so I couldn't keep the original brat intake, so matching up hoses and such has been interesting...
So I've got things switched, and it'll crank, but not fire... I've got no spark, and have tried lots of ghetto hook ups to make sure the coil's getting juice, but to no avail...
I also have a '78 wagon doner, that runs but no drive..
I've raped front CV's from the wagon to the brat, and have hooked up the coil but no dice...
There's an electrical connection from the firewall that goes up to the alt, carb, dist, etc, but there is a 2-plug connection that has nowehere to go on the doner intake, which had a place to go on the original intake...
Ideas, suggestions, HELP?!!
I'm close but still far from driving it . . . .
Super,
This Brat should have the tried and true "points and condenser" distributor.
If this is the case, the coil gets battery voltage on the positive terminal. The negitive side goes to the points.
The points need set to .018" gap
(do not clean the points with sandpaper.
use a burnishing file and clean with a folded dollar bill)
and the condenser has to be good.
Not a whole lot of folks know about points ignitions anymore
I did the same thing. Transplanted a 1979 intake and emissions onto a 1980 motor. Not a hard thing and you don't have to use all the wires.
Too many questions and too much to type. Send me your phone # and when's a good time to call and I will attempt to walk you through your situation.
Regards, Todd
Nope, not yet...
Its freakin' cold here right now!!
As per 2 am conversation with subaru3, i switched distrbutors and got all new vaccuum lines. The carb was leaking rather profusly (I don't know the part names but front driver side, on the front side opposite the fuel line), so i switched carbs for a another i had (looked much cleaner), and put on all new vaccuum lines matching the sticker on the hood, but this one seems to leak as bad... :(
Anyhoo, i may out ont a few more layers and go for it some more in a bit but the 33 degrees is rather uninviting...
It did knind of cough a bit (maybe its my imagination), but i shhould still gasket seal the intake and thread treat the intake bolts (thanx todd), but i want it to sputter and idel a bit, that'll be a lot more symbol of progress!!
Well Superu any progress yet? Did you get that Brat running again?
Thanks again Todd, it feels like progress!!
Saturday (when cell minutes are free, I'll call you again...
attached are pix of the engine bay, carb (with leaking location) and coil...
talk to you soon...
Talked on the phone last night with him for a couple hours. I pushed him in the right direction. He should have it running soon. It's just matching up the "mix and match parts"!
