Rollie715 Posted December 13, 2005 Share Posted December 13, 2005 Well, I may have found an 88 GL Wagon to build my offroad rig out of, but it might need another engine. One idea I had was to pick up another Sube to use as a parts car with a good engine and swap it into it. My question for you all is what all engines will fit? The 88 currently has an SPFI EA82 with 5-speed. Will other engines from 2WD, Autos, or other years bolt right into the 88? If so, then I'm looking for leads close to Bellingham WA where I can get an engine. Thanks Rollie Quote Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 Any other EA 82 engine is a direct bolt in, but you may need other parts from the donor car to complete the installation. If you put in a turbo, you'll need all the mechanical parts, plus the ECM and wiring harness, for example. You can put in a newer series motor, but that takes more engineering. Quote Link to comment Share on other sites More sharing options...
Rollie715 Posted December 13, 2005 Author Share Posted December 13, 2005 What all years did the EA82 come in?Rollie Quote Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 The engine was produced from 1985 to 1994. I know it was available in the DL, GL, GL-10, and Loyale wagons in those years. I don't know the years for other models. Quote Link to comment Share on other sites More sharing options...
zyewdall Posted December 13, 2005 Share Posted December 13, 2005 SPFI ones were from '87 (california, '88 elsewhere) to '92 ? I think the '93 and 94 Loyales were MPFi instead of SPFI but not sure on that. The engines are the same regardless of 2wd, 4wd, duel range or pushbutton, or automatic. At least the basic engine -- accessories might be different, and you would probably need to reuse the wiring harness and maybe intake manifold from the one you have now. I've also had trouble switching distributors when I put a '91 engine into an '87 SPFI -- the ECU didn't like the newer distributor, so I just put the old distributor on the new engine and it fired right up. You can also put an EJ22 in there ('90 and onward legacy) if you get an adaptor plate and the right ECU, for alot more power. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 13, 2005 Share Posted December 13, 2005 Well, I may have found an 88 GL Wagon to build my offroad rig out of,Thanks Rollie Huuuuumm wonder where you found that? Quote Link to comment Share on other sites More sharing options...
