brooklyn forester Posted December 21, 2005 Share Posted December 21, 2005 Hi, First, let me say hello to everyone, as I'm new here. I have a 98 Forester that I purchased new. Recently, I notice a noise from the rear right wheel (at least it sounds like that's where it originates). as I mentioned in the title, it's a grinding or whirring type noise. hard to describe. I live in NYC, and only have 38000 miles on it, but they're tough miles on mean streets. Any thoughts? bearings? i gotta find a mechanic, but i'd like to go there with some idea of what the problem is. at least appear to know what I'm talking about. I love my car, and this is the first problem i've had in 8 years. thanks steve Quote Link to comment Share on other sites More sharing options...
Andyjo Posted December 21, 2005 Share Posted December 21, 2005 sounds like a bad bearing, try turning one way, and then the other to see if the sound gets worse (turning while moving) Quote Link to comment Share on other sites More sharing options...
cookie Posted December 21, 2005 Share Posted December 21, 2005 Foresters and Imps have inadaquate rear bearings. The fix is to use a Legacy bearing for replacement. The noise could be several things but that is common, and you are right that you need a trustworthy garage. Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted December 21, 2005 Share Posted December 21, 2005 does sound like the tell tale bad rear bearing. beefy Legacy replacement bearing is what you want. To view pricing, or to order - go here: 1) https://www.subarugenuineparts.com/oe_parts_cat.html 2) look up by part numbers below bearing - 28016AA030 oil seal - 28015AA090 oil seal - 28015AA100 oil seal - 28015AA110 axle nut (recommended) - 28044AA000 snap ring (recommended) - 28035AA040 let me know if you have questions. this should get your whirring grinding noise sorted! Happy Holidays!! Jamie Thomas Jamie at chaplins.com *************************** http://www.subiegal.com Quote Link to comment Share on other sites More sharing options...
Andyjo Posted December 21, 2005 Share Posted December 21, 2005 Oh yeah, you're most likely going to need a shop to change out the bearing, because you're "supposed" to use a hydrolic press to get them in and out.. pain in the rump roast if you ask me. I've had it done 3 times now (twice they didn't know about the legacy bearing), cost about.. $300 labor + parts, but if you get parts via Jamie it'll drive your cost down Quote Link to comment Share on other sites More sharing options...
brooklyn forester Posted December 27, 2005 Author Share Posted December 27, 2005 Thanks for the replies. The noise doesn't change while turning either way. I took my father in law for a ride, and he thinks it is my brakes. Could rear brakes make noise when not stepping on the brake pedal? steve Quote Link to comment Share on other sites More sharing options...
brooklyn forester Posted December 27, 2005 Author Share Posted December 27, 2005 BTW... I don't know if it makes a difference, but it's a 5 speed. steve Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted December 27, 2005 Share Posted December 27, 2005 I am pretty sure the 98 Forester still used drum brakes in the rear. It is possible that the shoes are not fully retracting, for whatever reason, and rubbing against the drum. I guess I would try and gently pull the parking brake up while driving to see if the noise changes, but make sure you keep your finger on the button so you don't engage the ratcheting mechanism. Can you "feel" anything when you do this? You could also stick your finger through the rim to touch the drum after driving...If one is really warm and the other isn't too bad, then that may help guide you in the right direction. If it isn't your brakes, then it is the wheel bearing. 1998 Foresters love to chew them up and spit them out. Take care, Kevin Quote Link to comment Share on other sites More sharing options...
