subaru project
7 replies to this topic
#1 redsatt
redsatt
    New User
  • PipPip
  • 11 posts
  • Bloomfield P.E.I.
Posted 21 December 2005 - 07:56 PM
Hi all, this is my first post here and hopefully someone can help me with their wisdom! I am planning a project using a 1.8 litre engine from a 91 loyale, and i'm wondering if i can simplify things a bit. can it be possible to convert this to a carb and maybe get rid of some of the electronics? perhaps change to a coil and distributor? i was on a site that talked about converting these engines to work in aircraft and it indicated this may be possible, but no details on how. if anyone can help id appreciate it . thanks. If someone wishes to e mail me i can be reached at redsatt@hotmail.com
#2 Numbchux
Numbchux
    EJ conversion addict
  • 6,889 posts
  • Saginaw, MN
Posted 21 December 2005 - 08:06 PM
Yes, loyales came with what were called EA82 motors, They're already coil and disty, and in '85 and '86, came with a carb from the factory (MPFI and turbo was an option....), and many have upgraded to a Weber carb.
Some prefer the EA81 engines for planes...simpler, timing chain instead of belts, smaller....and there are a bunch of performance parts for them with the idea of using them in planes
#3 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 21 December 2005 - 11:22 PM
No timing chain either, camshaft is gear driven. Also lighter.
#4 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 21 December 2005 - 11:57 PM
Yeah u gotta love not having to worry about changing belts or chains....EVER. :-)
#5 wesley willis
wesley willis
    Eat, Live, Breath Subaru
  • 278 posts
  • port alberni, bc, canada
Posted 22 December 2005 - 02:37 AM
i changed the drive belt on my ea81, so never say never. :cool:
the ea81's are dang easy to work on though. most all are carb'd.
#6 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 22 December 2005 - 10:15 AM
Except for those few lucky people that have the Turbo EA81's...droooool.
#7 zyewdall
zyewdall
    Subaru Master
  • 2,136 posts
  • Ward, CO
Posted 22 December 2005 - 11:50 AM
If you are going to use the EA82 engine from the loyale, just find a '85 - '87 carbbed EA82 and you can swap the entire intake manifold onto it. The compression ratio is a little higher for the SPFI EA82, but other than that, the SPFI and carbbed engines are the same from the intake manifold down. You'll also need the distributor from the carbbed one.
#8 Ross
Ross
    Can't be bothered
  • 1,865 posts
Posted 22 December 2005 - 04:07 PM
Ay? what drive belt?
