How the EA82 manifold and carb swap unfolded...
8 replies to this topic
#1 JonOfScio
JonOfScio
    OMGZ!!! HATCH ATTACK!
  • 713 posts
  • Corvallis, OR
Posted 06 October 2003 - 10:48 AM
Well, some bad news. I got it all done, fitted on, and running. had a hard time idling, had little power.
When I first got it on, my disty died, so I replaced that, and now when I put my old EA81 manifold and carb back on, somehow, I have white exhaust. I don't think my heads are cracked, but you never know, and I can see water leaking slowly from the back of my engine when I look under the car.
Did I accidentally hook up some water stuff to my intake? I'm not driving it right now, and it's at Andrew's house. One way or another, we'll get it fixed, there is a spare engine I was going to purchase from him, so we'll be okay. got a spare engine for parts, it just needs new bearings, so we can use the intake and the heads if needed.
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 06 October 2003 - 04:50 PM
Chances are coolant is getting from the water jacket in the manifold, and getting into your intake. double check all your gaskets.
So the EA82 carb wouldnt run on a EA81?
-Brian
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 06 October 2003 - 05:42 PM
sounds like an intake gasket is leaking. did you know you can re-use a new gasket if you used silicone on it?
you can double them up, too. that is how i got my ea81 carb/intake on a spfi ea82
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 06 October 2003 - 07:14 PM
Sounds to me like you just have residual moisture in things. Watch the coolant level for a few days and see if the white smoke goes away.
#5 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 06 October 2003 - 08:15 PM
double them up? thats crazy talk.
#6 Adam N.D.J.
Adam N.D.J.
    Quite Rusty, but working.
  • 3,290 posts
  • Medford, Oregon
Posted 06 October 2003 - 09:23 PM
I've doubled up gaskets before, but not gasket to gasket. I've always cut out a thin sheet of either aluminum, or steel, depending on whats laying around, and stacked that in between the gaskets. Of course this was on (cough cough), V8's. You can do anything if you put some time into it.
Did you just use the EA82 intake, or both the intake and carby? The hitachi carbs that were on the EA82's were feedback, and relied quite heavily on the computer (you can get em to run without the computer, but it takes some fiddling.)
When you take of the intake, no matter how much you try not too, you always get some coolant that goes into the heads. depending on how much got in there, you can end up blowing white for up to a week. SO the best advice was already given, watch your coolant level, and drive the &*#! out of it, see if it clears up, if not, then I would check gaskets.
#7 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 06 October 2003 - 09:26 PM
Whats the purpose of doubling up on gaskets?
I say, lop a bunch of form-a-gasket on there... and call it good.
-Brian
#8 Geach
Geach
    New User
  • PipPip
  • 11 posts
  • Australia
Posted 07 October 2003 - 06:30 AM
I assume you used an EA82 manifold, if so there is the little hole with a small pipe sticking up beside the large hole where the fuel/air goes in. when I put the weber adaptor plate on with the gasket in between, it didn't quite seal it off and as a consequence water forced its way into the motor. to cut a long story short, I pulled it off again and blocked the hole with hard setting resin and put it back together. had a white exhaust for half an hour too.
I am not a big fan of silicon either, I seen it mess up gaskets rather effectively. use a real liquid gasket sealant as well as the papers. the water at the back sounds like you haven't connected up one of the little hoses on the manifold.
the poor idling sounds like a vacuum leak. I had to file off a little rise on the rhs of the manifold, coz it stopped the adaptor plate from sitting flush.
hope that helps, as you can see I had a few problems when I did it! :banghead:
#9 JonOfScio
JonOfScio
  • 713 posts
  • Corvallis, OR
Posted 07 October 2003 - 07:26 AM
the problem with how I re-put the EA81 manifold back on is that maybe I didn't tighten them down enough, and I'm basically 100% certain my problem is more of how the manifold is placed on the motor than anything else.
The problem with the EA82 manifold on an EA81 engine is that the disty doesn't allow much play, so you can't adjust timing acurately.
