EA82 blows smoke on right turns
17 replies to this topic
#1 Guest_subieman_*
Guest_subieman_*
  • Guests
Posted 27 July 2003 - 11:47 PM
My Loyale today just started to burn lots of oil on long right turns only. Like a freeway off-ramp where you are decelerating and making a turn. I mean it's blowing so much blue smoke it looks like a blue storm behind me and no one else can see where they are going. It does not smoke any other time but on those damn right turns. Not left, not straight.... Any suggestions? It's got me kinda worried.
It's on a 91 Loyale, 160k
Thanks
#2 Guest_Hondasucks_*
Guest_Hondasucks_*
  • Guests
Posted 27 July 2003 - 11:57 PM
Take off your left valve cover, and I bet the little baffle has come off. When you go around a right hand corner, centrifugal force throws the oil over to the left hand side of the crank case, and if that baffle isn't there, (or you have too much oil in your crank case!) guess where it goes, right into the intake, and BINGO, James Bond smokescreen!
#3 Guest_Wagon Wagon_*
Guest_Wagon Wagon_*
  • Guests
Posted 28 July 2003 - 12:04 AM
My old DL wagon had this same problem, and changing the PCV fixed it.
The PCV had been spewing oil into the intake, and a bunch of it had been collecting in the intake tube. Going around a long right turn, think about the layout of the piping... anything collecting in that tube will get pushed as far to the left as it can go, which would dump it right into the throttle body.
#4 Guest_Flowmastered87GL_*
  • Guests
Posted 28 July 2003 - 12:07 AM
PCV valve, I had a fram one and it smoked like crazy on turns. I installed a subaru one and it all stopped. Fram sucks :mad:
#5 Guest_GlCraigGT_*
Guest_GlCraigGT_*
  • Guests
Posted 28 July 2003 - 12:10 AM
here is a copy of the service bulletin that covers that
<a href="http://home.comcast.net/~c.moe/pvc_mod.pdf" target="top">home.comcast.net/~c.moe/pvc_mod.pdf</a>
#6 Guest_subieman_*
Guest_subieman_*
  • Guests
Hahaha. Okay that is funny. :lol: I just replaced the PCV valve 2 days ago with a Fram. Guess I'll be ripping that little $3 POS out of my car. Maybe even the Fram oil filter. ;)
Thanks.. if it's not the PCV or whatever in the valve cover... any other suggestions?
#7 Guest_GlCraigGT_*
Guest_GlCraigGT_*
  • Guests
Posted 28 July 2003 - 12:14 AM
now that i have the link fixed, you may want to read the info
#8 Guest_subieman_*
Guest_subieman_*
  • Guests
Posted 28 July 2003 - 12:17 AM
Interesting. If I go to the subaru dealership will they have this mod kit??
#9 Guest_GlCraigGT_*
Guest_GlCraigGT_*
  • Guests
Posted 28 July 2003 - 12:19 AM
maybe, or you could go to a wrecking yard and take the parts off of an 92-94
#10 Guest_rXSNRG_*
Guest_rXSNRG_*
  • Guests
Posted 28 July 2003 - 08:42 AM
Yes rip that Fram filter off your car, they are no good. I cut one open and the are all paper inside with no real bypass spring. Most filters have sheet metal filter end caps, rubber seals and bypass springs, but not Fram, they decided none of that was necassary:mad:
The paper seperates and travel through your oil passages and can get lodged in there and clog, go figure.
Almost any other filter made will be of better quality, you can't beat the OEM unit.
#11 Guest_Dennis_*
Guest_Dennis_*
  • Guests
Posted 28 July 2003 - 08:50 AM
OEM is made by purolator, most of the guys here on the board wont use anything but...
part number #24457
#12 Guest_lumpc1_*
Guest_lumpc1_*
  • Guests
Posted 28 July 2003 - 09:58 AM
Don't you watch TV, why would you want to turn right? :rollin: :rollin: :rollin: :rollin: :rollin:
#13 Guest_Meeky Moose_*
Guest_Meeky Moose_*
  • Guests
Posted 28 July 2003 - 10:56 AM
yeha, fram filters blow, i use purolators aon all my cars,\. for oil i use a purolator pure one. 286k and counting :eek:
#14 Guest_oobnuker_*
Guest_oobnuker_*
  • Guests
Posted 28 July 2003 - 11:20 AM
How about one of these:
<img src="http://www.arventerprises.com/subaru/IM001115.JPG" style="border:0;"/>
Shameless plug. www.arventerprises.com/subaru/arvoilcan.htm
#15 Guest_subieman_*
Guest_subieman_*
  • Guests
Posted 28 July 2003 - 12:13 PM
ok ok ok.. I'll stop using Fram products.. haha :lol:
Thanks for all the tips for my smoking subie fix. I'm gonna find a 92-94 Loyale and pull the emissions components off. That should fix it I hope. Sounds like a much cheaper fix then $30+ for that black can thing.
Thanks again! :D :D
#16 Guest_oobnuker_*
Guest_oobnuker_*
  • Guests
Posted 28 July 2003 - 12:35 PM
Wow! I guess I deserved that...Good luck.
If you can't find the components or they are brittle, a good plumbing supply house has all sorts of nylon fittings, elbows, tees, etc. and the tubing you need to do it yourself.
#17 Guest_subieman_*
Guest_subieman_*
  • Guests
Posted 28 July 2003 - 03:29 PM
oobnuker, Sorry about that, I did not mean any disrespect. I did not realize your making the part. :( No hard feelings?
#18 Guest_oobnuker_*
Guest_oobnuker_*
  • Guests
Posted 28 July 2003 - 03:59 PM
None taken! I DID shamelessly stick that in there ;)
Anyway - either way good luck.
