2002 Forester Clock- same problem as everyone else... goes on/off, now it won't work. Did they ever do a recall on this?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
2002 Forester Clock
Started by
DUTHAI
, Dec 28 2005 04:18 PM
3 replies to this topic
#1
Posted 28 December 2005 - 04:18 PM
#2
Posted 28 December 2005 - 06:03 PM
this is a common problem... if you did a search, you would have come up with:2002 Forester Clock- same problem as everyone else... goes on/off, now it won't work. Did they ever do a recall on this?
http://www.ultimates...=forester clock
#3
Posted 28 December 2005 - 06:27 PM
Dig into it,
It's probably the easiest fix your ever going to do on your Forester.
#4
Posted 29 December 2005 - 09:50 AM
My 99 forester clock went out too.
It's a very simple fix with a soldering iron. No need to go out an buy anything.
I'm assuming your's is the same. If you remove the clock (use a small screwdriver - there are two tabs that you need to undo), then unplug it.
Remove the clock from the plastic front (I actually broke one of the tabs doing this so be careful). On the back of the electronics, you will see several small rectangular pieces with numbers on them. Look for the one that has 510. Part of it is partially under the display and seems difficult to reach. This is a resister and it has lost it's connection to the board.
Just resolder to the board it it'll take care of it!
Check out the picture here!!!!!!
http://www.scoobymod...read.php?t=5028
