Wierd dash light problems! Help!
1 reply to this topic
#1 LeonasMan
    New User
  • Pip
  • 2 posts
  • Plattsburgh
Posted 28 December 2005 - 07:14 PM
97 subaru impreza outback sport 1.8
took out the oem tape player, installed a pioneer cd player. soldered wire connector from pioneer to a quick connect plug designed to fit into oem plug. Of course, had to disc. negative battery terminal to do it. When reconnected negative battery terminal, got the flashing lights syndrome. Don't have the keyless entry remote, so had to slide under dash and hold the game show buzzer. Did nothing, dash and headlights were still flashing. FOund out from dealer that I had to turn ignition key while pushing game show buzzer. Stopped the alarm. Now my dash lights wont work at all, nor heat/ac control lights either. Lights on cd player are fine, cd player works fine too. Thought it was a blown fuse, but they re all ok. Funny thing is, whenever I disc the - battery terminal again, the dash lights flash, but when I reconnect, they don't work!! Only light that works is rear defroster light, which is controlled by the same dimmer that controls the dash and heat/ac lights. and the aforesaid rear defroster light dims fine, just no other lights controlled by the same dimmer switch work....until I disc the - terminal again.... FYI also I noticed that when I had to press gameshow buzzer, there was a lil red light somewhere under there that flashed in accordance with the audible clicks and light flashing. After the problem happened, the light began flashing in its own pattern, about like a heatbeat, even after the alarm was reset. But now, a week later, the lil light doesnt light up at all, no matter what. Maybe it can help whoever solve this problem with me?
#2 LeonasMan
    New User
  • Pip
  • 2 posts
  • Plattsburgh
Posted 28 December 2005 - 07:20 PM
By the way, I noticed that there is a solid green wire in the oem harness connector that now connects to nothing, as the wires going into the cd player are all used, and there is no pin in the quick connect for the green wire to connect to anyway. But it DID have someplace to go in the oem tape player. is it some ground? or some power bypass/distribution thing? I'm new to all this, so please explain in laymans terms..
