island Posted December 29, 2005 Share Posted December 29, 2005 My 2000 Forester clutch pedal keeps sticking half way up in hot weather. The clutch engages but cruise control won't work in the stuck position. I have to put my foot under the pedal and lift it; it pops up. My mechanic has tried twice to fix it withour success. I know the subaru clutch is notorious and there are a million postings about them here but haven't found this problem here yet. Any suggestions? Quote Link to comment Share on other sites More sharing options...
color-blind Posted December 29, 2005 Share Posted December 29, 2005 My 2000 Forester clutch pedal keeps sticking half way up in hot weather. The clutch engages but cruise control won't work in the stuck position. I have to put my foot under the pedal and lift it; it pops up. My mechanic has tried twice to fix it withour success. I know the subaru clutch is notorious and there are a million postings about them here but haven't found this problem here yet. Any suggestions? Replace the clutch slave and the clutch hose. This is a common problem. I would also suggest the replacement of the clutch master cylinder while you have it apart. Good luck. Quote Link to comment Share on other sites More sharing options...
cookie Posted December 29, 2005 Share Posted December 29, 2005 On mine I replaced the slave and hose per the TSB. I still did not have enough pressure and replaced the master. Over 33,000 miles on the repair and it is still fine. Quote Link to comment Share on other sites More sharing options...
island Posted December 30, 2005 Author Share Posted December 30, 2005 Thanks for quick response. I have now found several others with the same problem on this site. I'll print out the relevant postings and take them in to my mechanic. We're a small town and don't have a local subaru dealer. Quote Link to comment Share on other sites More sharing options...
jokermtb Posted January 7, 2006 Share Posted January 7, 2006 98 Legacy GT....I had to replace my clutch MC and Slave at 89k, then again at 110k and now it's sticking down again at 128k!!!.......I had a new clutch to replace the origional clutch, installed at 110k also. This somehow doesn't seem right, 20k from a clutch slave cyclinder? I don't abuse my car, and I got almost 110k from my orig clutch plates, so I have to believe there is something inherently wrong/designed with the Subaru clutch Master cylinder/slave cylinder arrangement..... what a pain in the neck! Quote Link to comment Share on other sites More sharing options...
cookie Posted January 7, 2006 Share Posted January 7, 2006 You could have a small air leak or the linkage adjusted incorrectly, or just the worst luck I have heard of on these devices. Quote Link to comment Share on other sites More sharing options...
