thesubeguy Posted December 31, 2005 Share Posted December 31, 2005 in my sube i've got a twin core that every single time i remove it or put it in, it somehow seems to bend fins and all around mess it up. finally fed up with it i decided to cut into the radiator support from one side of the radiator to the other. worked incredibly well and now its a straight shot in and out with no hitting anywhere. definately recommend doing this for anyone with a twin core or if they just don't like fighting with the fan anymore. i'll get pics soon Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted January 1, 2006 Share Posted January 1, 2006 OR remove the fan Quote Link to comment Share on other sites More sharing options...
WJM Posted January 1, 2006 Share Posted January 1, 2006 OR install electric ones. I did the support mod...never do it again. Quote Link to comment Share on other sites More sharing options...
thesubeguy Posted January 1, 2006 Author Share Posted January 1, 2006 fan wouldn't come off without damaging the radiator in some way. wjm why wouldn't you do it again? Quote Link to comment Share on other sites More sharing options...
WJM Posted January 1, 2006 Share Posted January 1, 2006 fan wouldn't come off without damaging the radiator in some way. wjm why wouldn't you do it again? compromised structual integrity and its not allowed in the class I run my RX in. Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted January 2, 2006 Share Posted January 2, 2006 "fan wouldn't come off without damaging the radiator in some way" why is that so? all you would of had to do was remove the 4 nuts on the waterpump pulley, remove the 4 bolts on the fan shroud, if equipped, and pull up Quote Link to comment Share on other sites More sharing options...
thesubeguy Posted January 4, 2006 Author Share Posted January 4, 2006 even after removing the 4 bolts on the fan itself there wasn't enough clearance to remove the radiator without damaging it. now its just a straight lift in and out no hitting anywhere Quote Link to comment Share on other sites More sharing options...
NorthWet Posted January 5, 2006 Share Posted January 5, 2006 "fan wouldn't come off without damaging the radiator in some way"why is that so? all you would of had to do was remove the 4 nuts on the waterpump pulley, remove the 4 bolts on the fan shroud, if equipped, and pull up The clearance between fan and fins aon many 2-row radiators is very minimal. I have had much the same issues... Quote Link to comment Share on other sites More sharing options...
Turbone Posted January 5, 2006 Share Posted January 5, 2006 The correct mod here is what WJM suggested. Replace the clutch fan with electric. It mounts right to the rad, and its alot easier to remove. Quote Link to comment Share on other sites More sharing options...
rallyruss Posted January 5, 2006 Share Posted January 5, 2006 mine droped right in on the wagon and my old(junkies RX) stock fans and rad. support. I did have a problem on the wagon where the end tank on the passengers side was rubbing the rear of the head light bucket but that was from previously repaired front end damage if I am not mistaken. where are you guys getting your radiators from? mine were both from perfomance radiator if I rember correctly. Quote Link to comment Share on other sites More sharing options...
