zzzasy Posted January 3, 2006 Share Posted January 3, 2006 Posted earlier (Do I have cracked heads/block) about the situation I'm having with my '98 OBW. For background, I replaced the cats and O2 sensors because the cats burned up. Car had been sitting for maybe 2 months. After replacing the cats I had sensor errors on camshaft position sensor, so I replaced the camshaft position sensor and crankshaft position. Next it thru Knock sensor code, so I replaced the knock sensor. Took the car out and it runs fine when cold. When it reach operating temps it begans to sputter and cut back as if lack of fuel. So, I replaced the fuel filter. When I replaced the fuel filter the car seemed to drive a little better, but once it reached operating temp it began to sputter again. I followed Ferret advice from the previous post and unpulled the front O2 sensor. The car ran pretty much the same, but it got a little worst. Interesting thing was it did not throw a O2 code. Instead, I got a fuel temp sensor code. I assumed this may have come from the new fuel filter, so I cleared it. Haven't taken the car out for a long drive, but when I did drive it this morning for a few minutes, no codes had come back. I will drive it when I get off to see if the code returns. What do you guys think I should look at next? It appears to be more of a fuel problem than an electrical one. I just changed out the coolant, and it is black already; so could that be part of the problem. But, if that is the problem wouldn't that be present rather the car is warm or cold? Does the fact that it doesn't do it when cold sort of means its not a cracked head? Just searching for clues before I have to turn it over to the MAN. Should I replace the IAC? zzzasy '98 OBW Quote Link to comment Share on other sites More sharing options...
hohieu Posted January 3, 2006 Share Posted January 3, 2006 Could be the coolant temperature sensor. This sends signals to the computer and modulates fuel mixture and ignition accordingly. However, black coolant doesn't sound promising. Good luck. Quote Link to comment Share on other sites More sharing options...
zzzasy Posted January 3, 2006 Author Share Posted January 3, 2006 replaced coolant temp sensor (CTS) about 7 months ago. Also, the cooling fans appears to be coming on. If the CTS was bad, the fans would not be working, right? Also, the car has shown no signs of running hot. zzzasy '98 OBW Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted January 3, 2006 Share Posted January 3, 2006 Is it cutting clear out, than restarting itself on a regular cycle, like three to five seconds? Our 2000 Leg did that, it turned out to be the fuel ratio sensor, and a reprogram (wider range) for the ECU. Search the mtsmiths posts and you find a long and weary history, then final resolution. Quote Link to comment Share on other sites More sharing options...
zzzasy Posted January 3, 2006 Author Share Posted January 3, 2006 will do. No its not stopping. There will be lag, pickup, lag, pickup. It constantly goes like that. It has never sputtered out. It always picks back up. Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted January 3, 2006 Share Posted January 3, 2006 Sounds just like ours. Feels like it's shutting off, but always catches and keeps going. Gotta be hard on U-joints, In fact, I think I now notice pick-up and deceleration slack in ours! Quote Link to comment Share on other sites More sharing options...
