MSSLGECKO Posted January 4, 2006 Share Posted January 4, 2006 Hey, can I run the stock EJ22 manual tranny in my EA81? I recall someone on the board was working on running the EJ tranny - how hard is it and how does it work? What axles are used? I'm thinking it might be a little easier for me to carry the tranny over w/ the engine instead of spending $$ on a clutch, adaptor, flywheel, etc. What do you think, can I do it for cheaper this way? Thanks, Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 4, 2006 Share Posted January 4, 2006 The axles will have to be custom, but i think that the guy from MWEAxles should be able to do it for you with little or no extra cost. You'll need the standard EA-81 axle and then the turbo EA-82 inner cup, because the splines are different on that transmission stub shaft. You'll also need a custom drive shaft, either get the legacy one shortened and weld in the carrier bearing, or go with a one piece. As far as mounting the tranny, custom mounts should be as easy as fabbing up a crossmember, so i hope you have a welder, or have a friend with one. Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted January 4, 2006 Author Share Posted January 4, 2006 Thanks for knowing the axles needed. Howabout the shift linkage? Will I need a welder to make it fit? For the Xmember, could I use the stock 4SPD D/R one and weld onto it to make it work w/ stock EJ mounts? Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted January 5, 2006 Share Posted January 5, 2006 Noah....Are you saying you want to run the Awd trans behind the 2.2 in the Ea-81 car..? This is John ( aka ) mudrat79 at Brads House..on his computer If so it is very doable... Also, I can stick A custom set of 23 spline axle stubs into the AWD trans so you can run stock axles as well..... Call me on it I have a Trans at the house right now if you don't already have one....and if you do I can do the work to this one then just trade you out for tranny later...? Chat soon, John Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 5, 2006 Share Posted January 5, 2006 if you go 5 lug you wont have to get custom axles.....sorry....voice from the darkside......... ~Josh~ Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted January 5, 2006 Author Share Posted January 5, 2006 John - I'll give you a call tomorrow sometime about this. Thanks for saying something, running stock axles will help keep costs down! As for the 5-lug, I've thought about it but as long as I'm able to get Peugeots, I won't need more lugs. Plus, IIRC it's hard to find any definitive information on the swap into the EA81 - most is regarding the EA82. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 7, 2006 Share Posted January 7, 2006 i just asked this question last night,have you found out more? Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted January 7, 2006 Author Share Posted January 7, 2006 i just asked this question last night,have you found out more?Yeah, just what John posted - swap the spline shafts for the proper EA82 ones - I'm going to use PB 4WD ones. Then the stock axles will work a-okay. And shorten the drive shaft to match the brat wheel base of course. I'm super stoked to find this out because I'm going to save myself a good amount of cash by avoiding the adapter plate and clutch/flywheel. I've decided that I would rather have the EJ AWD tranny than any PT EA82. The only thing that would make running an EA82 tranny for me would be if I had a D/R FT4WD from an RX. Quote Link to comment Share on other sites More sharing options...
