5Speed D/R Swap?????
17 replies to this topic
#1 Scrub2k
Scrub2k
    Eat, Live, Breath Subaru
  • 273 posts
  • Reno
Posted 08 October 2003 - 01:17 AM
Approx. How Long Would it Take to Swap My A/T Out for a 5Speed D/R Tranny, and what all would i need other than the tranny? do i need a new rear driveshaft? Im Basically Asking if this is possible for me and maybe one other guy to do in a weekend? or should i plan to have the car down longer?
Thanks In Advance.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,768 posts
  • Portland
Posted 08 October 2003 - 01:26 AM
You need the whole clutch package too - and the pedal assembly, as well as the interior boots / console's and all the proper shift linkage. Also - I'm not sure on the EA82's but you may need a different tranny cross-member as well. Axles may be different if either of the tranny's was from a turbo, and the other wasn't.
#3 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 01:28 AM
Hrm, my car is a Turbo but the car that im looking at for the Tranny Is a 88 GL Non Turbo.
#4 hmmmnz
hmmmnz
    New User
  • PipPip
  • 15 posts
  • wellington new zealand
Posted 08 October 2003 - 01:39 AM
it shouldnt take too long. its only a matter of 4 bolts on the gear boxand a couple on drive shaft .. the drive shaft i beleive is the same.but this is where the problems beguin. after ripping the old auto out. you ll have to do some cutting a mission but not so bad if you have another car to take measurements from.. also there is of course the fly wheel from a manual. your fuct if you dont have that. then there is the clutch kit, clutch cable, foot pedal,mounting brackets. ect ...it can all be done in a weekend. but thats only if you are really quite organised ....
also dont quote me on this but i seem to remember something about the auto and manual diff ratios being different as well it might be worth looking into.. i think the usrm link at the top of the page might be able to tell you for sure.. well if i think of any thing else ill let ya know... good luck your gunna need it.
#5 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 01:43 AM
thanks it really sounds like i will need alot of luck and some patience :banghead:
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2003 - 01:50 AM
I heard the peddle assembly was the hardest part. Soobme did a A/T to D/R 5spd swap on his Turbo GL10. He said the tranny's swapped right over, not sure about the driveshaft. But the peddle was the hardest part. He said if you take the drivers seat out, it makes it alot easier.
What weekend are you planning on doing this? I can get a sunday off and come up to help if you need it.
-Brian
#7 subieman
subieman
    1000+ Super USER!
  • 1,422 posts
  • Sparks, NV
Posted 08 October 2003 - 01:52 AM
I have sunday off too.. But I think I'll be in California. I'll lend a hand if my plans change.
#8 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 01:57 AM
Im Not Exactly Sure at the moment, Moneys really tight right now, and im not sure if the car i was looking at got crushed or not :( if they dident crush the car and i can get the parts it will probably be within the next month, i will keep you posted.
Thanks for the Help. :D
#9 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2003 - 01:59 AM
Cool. Well, the Junk Yard here will have the parts you need, and its 1/2 price weekend on the 17 and 18th.
-Brian
#10 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 02:02 AM
Hrm Any Idea How Much it Would Come too? i might be able to come up with the money and drive over to sac.
#11 subieman
subieman
    1000+ Super USER!
  • 1,422 posts
  • Sparks, NV
Posted 08 October 2003 - 02:04 AM
Is there anything wrong with your 3speed?
#12 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 02:07 AM
Well I Have No 4WD and I have Wierd Clanking/Grinding Noises Im Not Familiar With These Cars and I Was Told That the Noise is Probably A Gear Issue or Something to That Nature, And Im Not Sure Whats up with the 4WD yet i havent checked into that part yet.
#13 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2003 - 02:54 AM
Dont forget, its an AT... and thats reason enough to change it. on 1/2 price day... hrm... $150 tops i would think. If it were any more than that, i would be shocked. I'll talk to Tony and see whats needed. Then call PnP and check with them. They're webpage sais "transmissions from $74.99" So on 1/2 price weekend i would think after core, your tranny shouldnt be much more than $70-$75 after tax and everything. Then guestimate aprox $75-$100 for other odd's and ends like flywheel, peddle assembly, and drive shaft. If your AT and 5spd dont have the same gear ratio, you'll need the rear diff as well.
I believe all AT's have the same spline count as non-turbo 5spd DR's
-Brian
#14 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 08 October 2003 - 08:30 AM
All info below is given assuming you will be swapping in a non turbo, non RX type D/R tranny.
ok.. here we go.. I just did the Auto to manual swap a few months ago.. I didn't use the D/R, I used the S/R but for the most part my info still applies.
There was a reference above to cutting something or other.. Don't know what that is about.. there's no cutting to be done.. except a couple of wires for your reverse lights:D
If you have the 3AT, the axle spline count will be the same as the D/R ( non-RX type)
If you have the 4EAT,on a turbo car, they do indeed use the 25 spline turbo axles(thats new to me,but was given by a reliable source)
Pedal assembly is a real pain. definitely the hardest part.
You will need the rear driveline for a manual car. you will need a flywheel. you will need a clutch kit. These come with TO bearings, but don't generally come with the clips for the TO bearing.. you will need the tranny crossmember along with the rubber mount/bushings that go with ityo will also need the shifter assembly and center console trim pieces.. don't forget the reverse spring on the shifter linkage.
One thing that hasn't been mentioned is that you have the option of swapping out the master cylinder/brake booster for one that has the Hill Holder set up. I opted not to do that as I was in a time crunch. if you choose not to use that setup, you will have to have a seperate return spring on the clutch fork.
You will also have to get the rear diff from the donor car, as yours is 3.7, and your new tranny will be 3.9.
I'm sure there are a few things I missed. Its a big job, but its not as hard as it sounds. I will be happy to answer any specific questions you may have
#15 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 08 October 2003 - 10:35 AM
when getting your 5spd, get the entire clutch/flywheel, and the flywheel bolts. you will also need the driveshaft and rear diff.
being that your car is already 4wd, the drivshaft and diff will fit the same.
the clutch pedal box(all 3 pedals in one assembly) will fit the same. i would remove the steering column, since it goes through the bedal box, it comes out with 2 bolts and some electrical connections. there will be a rubber plug covering the hole that is already there for the clutch cable. when getting the pedal assy, disconnect the clutch cable from the tranny end, and leave it connected to the pedal end. grab the grommet from the donor car if possible.
the padal assy is held on by 4 studs that come through the firewall from the brake booster assembly, and the top half bolts to the steering column for added support.
put the pedals in with the 4 nuts, then the steering column, then the top bolts after that.
there is a flat spot on the steering shaft, that the retainer bolt fots across, it will only go on one way, make sure your wheels are straight when doing the steering column.
the hole for the inner shifter boot may be a little different, but the outer boot/plate will snap right onto the center console where the at's used to be, all will fit like its supposed to.
the only clue to it was an automatic is PRND1 on the instrument cluster!
the axles will use a 3/16 punch, dont use a 1/4 inch, or it will get stuck! there is a concave side on the axle to drive the pins out/in from.
when doing the diff, drop the mustace bar from the 19mm nuts, and articulate it one way and then the other to slide off each axle.
when dong the trans, and assuminf the motor is out, you can pull the tranny one way or the other to slide the axles on one way otr the other.
the axles only fit on one way, if its 180 off, the holes wont align exactly.
slide the punch through the holes to line them up before driving in the pins.
also, if you dont have the clutch center tool, as if using the same clutch if it is still good, you can do the clutch this way:
have the starter removed from the tranny. put the clutch disc on the flywheel, then mock up the pressure plate and thread the bolts in finger tight. the isea is its tight enough to hold the clutch disc still, but will be allowed to slide around by hand. that way it woll give enough to find its way onto the tranny shaft. once the motor is almost aginst the trans, wiggle the motor around until the shaft finds its way into the pilot bearing.
with the starter still out, and the motor against the tranny, now you can get in there with a 12mm socket to tighten down the 6 pressure plate bolts. now put on the starter, the thru-bolt that goes on the top of the starter holds on the battery ground cable, dont forget that because i always do!
a few tips of expertise from This Fox!:D
#16 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 11:35 AM
Is it easier to do the Non D/R 5 Speed? or should i do the d/r just so i have the Low option when i need/want it?
#17 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 08 October 2003 - 11:52 AM
any MT swap is the same amount of work.
all the shifter mechanism can stay connected to the tranny. the only difference between a d/r and a single range is the shifter cover plate. the d/r will have the hole for the lever, and will still bolt up to the body like its supposed to.
just behind the shifter hole, on the underside, is a stud that the shifter mound goes to on the automatic's body.
you can take the shifter linkage off the tranny in one oiece if you wish, it s fine either way.
the only thing you will have to do thats not already there is bypass the neutrak safety switch(you can jump a wire on the auto shifter's wiring plug- in, or just make a pushbutton starter swit) you will have to re-wire the my for the reverse light, and there will be nothing for the 4wd light indicator to plug in(for the lo on the 4wd lever)
but all the physical fitment of everything will fit as if the car was already an MT!
take it from me, i put a 4wd5spd in a 2wd ea81, put one in a 4wd auto ea82 sedan, and converted a 2wd auto sedan to 4wd 5spd!
so i know what's involved in any possible 5spd/dr conversion, as well as a good number of board members.
if you tackle this on, and run into a problem, just ask the board, because enough of us have done this in a number of our own ways, so at least one of us will have the answer to your specific method of going at it!
#18 Scrub2k
Scrub2k
  • 273 posts
  • Reno
Posted 08 October 2003 - 11:59 AM
Allright now its just coming up with the funds to get everything done, but i start a new job today so hopfully i can get this done before Dec 11th(Thats when my new Son is Due :-) )
Thanks for the Help Everyone
