Flex Plate Bolts
7 replies to this topic
#1 lakroy
lakroy
    New User
  • Pip
  • 1 posts
  • albuquerque
Posted 07 January 2006 - 02:29 AM
I am trying to remove the engine in a '98 Legacy Outback w/auto. I cannot get the flex plate bolts to budge. Does anyone know if there is a trick - could they be LH thread? Any help would be greatly appreciated.
George
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,282 posts
  • Houston, Tx
Posted 07 January 2006 - 09:13 PM
They are normal threads. You just have to work at them.
#3 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 08 January 2006 - 01:12 AM
If you can get a box wrench on them if you hit the end of the wrench with a hammer it works like an impact gun.
#4 avk
avk
    Certified Subaru Nut
  • 902 posts
  • NJ
Posted 08 January 2006 - 01:16 AM
I guess the trick, if there is one, would be to access those bolts from the bottom, but I didn't have to do it myself.
#5 RallyKeith
RallyKeith
    Got Subaru(s)?
  • 1,447 posts
  • Reading, Pa
Posted 08 January 2006 - 08:25 AM
Use a heat wrench, and carfully. I used some heat and a breaker bar. Have to be careful though about getting too much heat in there or you could damage the rear main oil seal... but if your in there already it only cost about $11 for the rear main seal at the dealer and it's worth replacing.
Keith
#6 lmdew
lmdew
    _______
  • 2,362 posts
  • Colorado Springs
Posted 08 January 2006 - 09:23 AM
1/4 drive ratchet with 6 point socket, then slip a box wrench over the ratchet handle to extend the lever. It fits in the tight space and gives you the leverage you need.
#7 who1981
who1981
    USMB Regular
  • PipPipPip
  • 64 posts
  • Longview WA, USA
Posted 08 January 2006 - 12:06 PM
If these things are as stuck as some I've seen:
Get a good Impact style 6 sided socket (not 12 point...I had to buy one), then grind the bevel off it, so you get more bite... :grin:
Don't go messing around with sloppy sockets/wrenches, and round out those low profile suckers! :eek:
If that alone doesn't work, use a lil' torch to heat them to a dull glow, then let them cool a minute before trying again...
Also a good impact driver is really helpful.
Cheers
#8 JPX
JPX
    Eat, Live, Breath Subaru
  • 286 posts
  • San Jose
Posted 29 January 2006 - 11:11 PM
I had to use an offset 12/14mm box wrench to get them out on the top side. get a friend to hold the crankshaft so you can put both hands on it to keep it straight. They weren't on all that tight on mine.
There was no combination of u-joint extensions I could come up with that would take those things off from underneath.
