Code 35: which solenoid valve?
16 replies to this topic
#1 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 08 October 2003 - 06:00 PM
Hey guys,
About three weeks ago I got code 21 for the coolant temp sensor. I was having hard starts and fuel odours. Replaced the sensor and all that went away. Great.
Now I'm getting code 35 for a solenoid valve. The Haynes manual calls this the purge control solenoid valve, but refers to the section on EGR control solenoid.
Anyone shed some light on this? And advice on what to do about it?
Thanks
#2 nickb21
nickb21
    Subaru Fanatic!
  • 567 posts
  • Hunterdon County
Posted 08 October 2003 - 10:27 PM
The purge control solenoid controls the passing of gas vapours to the charcoal canister. If it goes bad (stuck closed) it could result in hard starts, you can also get fuel odors since the canister can become saturated since the fumes won't be drawn into the motor for combustion.
Should only be 2 hoses and maybe a wire or two, not sure where it would be though..
#3 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 October 2003 - 12:04 AM
You don't state which car/year/model/engine.. those things are important if we are to help diagnose a problem
#4 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 09 October 2003 - 07:14 AM
91 Legacy, naturally aspirated, 5 speed, FWD, EJ22, 205 000 km
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 09 October 2003 - 07:43 AM
yeah, it's just the canister purge solenoid.....nothing to get super excited about. You should replace it eventually.
#6 Tolerance02
Tolerance02
    Subaru Fanatic!
  • 397 posts
  • Flanders
Posted 09 October 2003 - 04:13 PM
It's located near the coolant temp sensor you already replaced.
Under the intake manifold on the right (passengers LHD) side.
Two small rubber hoses and a two wire plug are connected to it. One of those hoses comes from the top of the trottle housing.
Just a thought, mabe one of the hoses or a wire was broken while you replaced the coolant sensor?
Urban.
#7 Lorryb
Lorryb
    USMB Regular
  • PipPipPip
  • 70 posts
  • Manitoba
Posted 10 October 2003 - 09:09 PM
The PV Solenoid is under the intakes on top of the engine, passenger side, you can see the two little hoses and the plug if you look between the pipes. Its easy to get out but a bitch to get back in. You need about a 10" extension on your ratchet to get at it from the rear of the engine. I don't remember what size the nut is holding it on but a previous post mentioned the size. The hard part is getting that nut to start after you replace the PVS. BTW, my check engine light was on for over a year cause I never got around to changing it. Never noticed any improvement in mileage or performance once I did except that the CEL ain't on anymore. YMMV
#8 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 10 October 2003 - 09:49 PM
Ok, I think I get it. As I understand it, there is no EGR system on my particular vehicle. I have located the solenoid valve under the intake manifold pipes with the little rubber hoses doing 180 degree bends. It does look like a tight area to work in. Looks like the bolt has clear access, though so should be able to stack up extensions to reach it. First thing though will be to clear the codes and see if it comes back.
#9 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 11 October 2003 - 01:55 PM
It's nothing to lose sleep over, my Legacy had a CEL on for over a YEAR carrying that code. (That was when I was working min. wage and could barely afford gas:banghead: ) It apparently was a very troublesome part, as it's been hashed over here before.
The part is a dealer-only valve that costs about $80 and I didn't do it myself, that was before I had any mechanical aptitude... So I can't vouch for its difficulty of replacement, but it looks hard :lol:
#10 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 11 October 2003 - 04:51 PM
Basically the reason I want to fix it is because I have an emissions test coming up and they won't (legally speaking, at least) do it if the CEL is on or comes on during the test. Stupid e-tests... grrr
#11 Brettm57
Brettm57
    USMB Regular
  • PipPipPip
  • 92 posts
  • Whitesville, NY
Posted 15 October 2003 - 07:52 AM
For what it's worth, I found an industrial type 12v solenoid valve in the McMaster-Carr catalog for about $17.00 that I think would work in place of the $80.00 (you gotta be s***ttin' me!) OEM part. The next time I replace one, and apparently it's a fairly problem, I'm going to try one. If you're interested, I can look up the part # and post it here.
#12 Brettm57
Brettm57
    USMB Regular
  • PipPipPip
  • 92 posts
  • Whitesville, NY
Posted 15 October 2003 - 09:44 PM
That's supposed to be: ....A fairly COMMON problem....
#13 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 16 October 2003 - 06:02 AM
Thanks, Brettm57. For now I have reset the code and have driven about 1000 km since and nothing has come up. The hard starts I had before were due to the water temp sensor which was done. It now starts right away, like it always did.
Still haven't done the e-test. Work, etc don't leave much time...
#14 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 16 October 2003 - 07:35 AM
the cpv will intermittantly go out and then come back on. You'll probably get away with this for several thousand miles. In the long run, you will need to replace it. But it's not a urgent part to replace.
#15 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 16 October 2003 - 11:11 AM
Cool, in that case I will attempt the e-test soon before it comes back on :D
#16 Legacy
Legacy
    New User
  • PipPipPip
  • 32 posts
  • Canada
Posted 16 October 2003 - 05:46 PM
As though it KNEW what I wrote on the board, my car threw me the code on the way home today, and on the next trip out later on. So it's replacement time. I'm looking for confirmation of the part #. I lifted the number off the valve under the intake manifold pipes on the RHS and got 14774AA350. I talked to the local parts guy and he says it is superseded by 14774AA351. I wanted to confirm this is the right part, since the Legacy parts sheet shows this valve as #4 on p. 344 (Emission components), but there isn't an intake manifold shown in dashed lines or anything like that, which would have located it.
I appreciate everyone's patience toward this thread which has probably been around longer than it should have been.
#17 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 16 October 2003 - 08:27 PM
parts guy is correct, it's been superceeded.
I wouldn't spend over 65 on this valve from a local dealer. If they want much more over that, order it from one of the online subie dealers www.newsubaru.com is who I use.
