88 RX spare tire
9 replies to this topic
#1 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 08 October 2003 - 09:03 PM
Do you have to run a full size spare with the ft 4wd trans or can you run a donut or in this case a 13" tire with the rest of them being 14" on Pugs.
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2003 - 09:19 PM
I wouldnt. Disable the FT4WD via the fuse under the hood.
-Brian
#3 ShawnW
ShawnW
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 08 October 2003 - 09:41 PM
Fuse? The trans didnt come with one. Is there really a fuse??
#4 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 08 October 2003 - 09:58 PM
i thought it was only for the AT's (fuse).
I would think with the center diff open (not locked), it would be okay. wouldn't go far though, especially if on the rear, because you'll be putting wear on the LSD clutch plates because of the diff. sized tires....
#5 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2003 - 10:11 PM
My roomies 5spd FT4WD (s/r) 5spd has a FWD fuse. But it doesnt do anything.
I guess mick is right, with the open center diff it shouldnt do any harm. But I would put the donut on the front to save the rear LSD
-Brian
#6 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 09 October 2003 - 07:15 AM
Well that I'd like to see, since the Fulltime 4WD standard transmission is mechanical and not electrical, what would a fuse have anything to do with it.
Shawn, I would advise against driving with odd sized ties on a Fulltime 4WD car. On UltimateRX, I had a full size spare that I was going to carry in the back. Mainly because the modification eliminated the spare tire space in the engine bay.
#7 ShawnW
ShawnW
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 09 October 2003 - 08:59 AM
Thanks Corky, I will start looking for another 14" pug alloy and go buy a tire.
I was thinking UltimateRX had an EJ series trans in it. My 90 Legacy had a donut in the back and was AWD so that is why I was thinking the RX trans would allow for it too.
#8 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 October 2003 - 09:09 AM
Shawn, I will five you a heads up before I go to the pull a part next time. There were 2 14 inch alloys there last time.. and soob and pug stuff doesn't move very fast around here.
#9 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 09 October 2003 - 09:20 AM
actually, you can have an odd size tire on one or the other axle, as long as the other tire is the same size as at least one tire on the other axle. , because of the open front and rear diffs.
its having 2 of the same size on one axle that is a different size of both tires on the other axle, that is what will bind up the center diff.
there is a 15a fuse for the 5spd single range in the gl-10, but 4wd button works with it IN
#10 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 October 2003 - 10:29 AM
The car in question is A Full Time 4wd not Push button 4wd.. no fuse, no button.
Corky is right on this one(as usual).. the best thing is definitely to get a full sized spare.
