2000 Outback cuts off on hard left turn
10 replies to this topic
#1 Evereddie
Evereddie
    New User
  • Pip
  • 7 posts
  • Triad NC
Posted 12 January 2006 - 09:18 AM
Hello everyone! This looks like a great place to get some help with my 2000 Ouback. Suddenly I am having problems with the engine cutting off or comming close to it on a hard left turn. I have seen a reference to this symptom when i do a Google search but no real info or resolve. Car has 110,000 miles on it.
Anybody know anything about this or lead me in the right direction for help.
Thnx for any help.
#2 ctoth
ctoth
    USMB Regular
  • PipPipPip
  • 88 posts
  • Perkinsville
Posted 12 January 2006 - 09:55 AM
sounds like a fuel pick up issue to me. Something isn't right in your tank.
#3 JohnnyB
JohnnyB
    USMB Regular
  • PipPipPip
  • 85 posts
  • Phila
Posted 12 January 2006 - 12:42 PM
Do a search here for "torque bind", should give you plenty to read. The easiest thing to check first would be to see if your tires are all inflated to proper spec and have similar tread depth. This happened recently to me, but it was on a right hand turn, had a slow leak in one of the tires, good luck.
#4 Evereddie
Evereddie
    New User
  • Pip
  • 7 posts
  • Triad NC
Posted 12 January 2006 - 04:43 PM
Thanx guys. I looked into "torque bind" and while it is something to be aware of that is not the problem. I put in the fuse, got the FWD light on the dash and car still cuts off or hesitates badly on hard left turn. (all tires up to proper pressure) It does seem fuel related since I doubt amy electrical components would be affected by a hard left turn only. Right turn doesn't affect it. Will top off the tank and see if it is any difference. Tank has been lower than half while I first started having this problem.
#5 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 12 January 2006 - 10:07 PM
i think there is a pressure switch in the p/s system some place. The purpose of this switch is to have the computer raise the htrottle speed a hair when turned to lock. If this switch isnt working the car will stall on turns. One thing to try (got strong arms? turn the wheel to full lock. Remove the ps belt and make the car cut a circle. If it doesnt satll its cause the PS system is loading uo the engine and the switch is not compensating for it. Just an idea.
nipper
#6 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,359 posts
  • Columbus
Posted 13 January 2006 - 02:22 PM
sounds like a fuel delivery problem to me
#7 Subie Gal
Subie Gal
    GC84Ever
  • 1,451 posts
  • WA
Posted 14 January 2006 - 04:58 PM
try to pay attn to your fuel levels when this happens
my subaru's have done this at just above 1/4 tank and lower
in hard cornering there is fuel depravation
& the car stalls momentarily
Jamie Posted Image
#8 Needcoin
Needcoin
    New User
  • Pip
  • 7 posts
  • Montreal
Posted 15 January 2006 - 10:42 PM
Sounds familiar, I would also have a similar problem with my 93 Legacy L, when my tank was at less than 25% fuel load, the car would hesitate when cornering hard, I assumed it had to do with the fuel pump. have you attempted to check fuel level in your tank when you corner?
#9 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 15 January 2006 - 11:21 PM
This has been a tendency of Japanese equipment for a long time. Do a google on Koga's Zero. Seriously this is probably a pick up problem and some times the end can rust off a pick up tube leaving you unable to get the fuel in the bottom of the tank. These are odd tanks too, one guy had that problem and it turned out his fuel gauge was off. He ran out of fuel right in front of my house while we were testing reading a hald tank. He is too broke to fix the gauge but now he knows how to use his odometer.
#10 Evereddie
Evereddie
    New User
  • Pip
  • 7 posts
  • Triad NC
Posted 16 January 2006 - 10:22 AM
Thanx guys for the increased info. I finally got to do some testing and it looks like is is fuel related and not electrical. It is also related to how hard I corner, have done extensive testing in parking lot. I lock the car in various turn radiuses and start acelerating. It reaches a point where it cuts out. I am at 1/4 tank and today will fill it up and repeat tests. Fuel Guage is OK. Will let you know.
Ahh! But fuel injection at least does not have THAT problem.
While the Zero was supremely maneuverable at low speeds, its controls became heavy at high speeds, and it rolled to the left much more easily than it rolled to the right. Also, due to its float-type carburetor it tended to stall under negative gees, as would be encountered if the Zero were climbing and then had to bob back downward while remaining upright. An American fighter could escape the Zero by bobbing up, diving while the Zero's engine stalled, and then rolling to the right. Japanese writer Masatake Okumiya, author of the classic book ZERO, claimed that the loss of Koga's Zero was no less serious than the Japanese defeat at Midway.
#11 cookie
cookie
  • 3,058 posts
  • SFO
Posted 16 January 2006 - 02:52 PM
yep, the cheapest fix may be the one my friend did. He has it figured now how far he can go and just fills up then. Good luck and thank Koga for me.
