Checking a 99 VSS output???
3 replies to this topic
#1 lmdew
lmdew
    _______
  • 3,742 posts
  • Colorado Springs
Posted 12 January 2006 - 07:51 PM
I have a 99 Legacy with a faulty Speedo. I've searched the threads, but have not found the correct voltage outputs from the sensor. This is on a manual trans, single connector with three pins.
Thanks, Larry
#2 Gnuman
Gnuman
    1000+ Super USER!
  • 1,399 posts
  • Richmond, CA
Posted 12 January 2006 - 08:32 PM
That is because it is not a voltage, but a signal. sort of like :
_|-|_|-|_|-|_
Well, something like that. the more ticks per second, the more speed, and the higher the needle goes. At least that is what goesw into the ECU. I'm sure that the guage uses something similar.
#3 Slegacy96
Slegacy96
    Eat, Live, Breath Subaru
  • 347 posts
  • West Chester
Posted 12 January 2006 - 10:09 PM
Yeah I got the same thing which has been fixed and still doesnt work. SOA is gettin a nasty letter but this except I have to go buy a 2 cent stamp. What a world.
#4 lmdew
lmdew
    _______
  • 3,742 posts
  • Colorado Springs
Posted 13 January 2006 - 07:42 PM
I pulled the VSS to drive it by hand and check the speedo and the VSS broke in two. After installing a new one and tightening the screws that hold the speedo to the dash all is Fine.
For owners with this problem, it may be worth a try to remove the dash and then one at a time remove clean and reinstall the 5 speedo screws.
