SubaRube Posted October 9, 2003 Share Posted October 9, 2003 What's the best way to check the tension of my belts? They have been slightly squeaking for a week or so, and now I started hearing the water circulating behind the dash alot more. Hope it isn't the water pump. I know I'm an idiot , how about some help? Anyone? Quote Link to comment Share on other sites More sharing options...
archemitis Posted October 9, 2003 Share Posted October 9, 2003 i use a crowbar on the alternator, and get the belts as tight as i can. no more squeaking. Quote Link to comment Share on other sites More sharing options...
SubaRube Posted October 9, 2003 Author Share Posted October 9, 2003 That's what I was hoping someone would say. Me like easy fix. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 9, 2003 Share Posted October 9, 2003 HEY! You stole my method! That's how *I* do it..... no fair! The water ou hear is air bubbles in the heater core - you need to let the air out. Park it on a hill (nice steep one), and turn the heater on to get coolant flow into it, then remove the radiator cap with the car running - should fix up your problem. GD Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 9, 2003 Share Posted October 9, 2003 Ummm to tighten the alternator look at the back of the long pivot bolt... this is the BajaVWSCoobnut method.... use a 14mm combination wrench on the back nut (use the open end as its not a perfect hex) then use the wrench to put tension on the belts... then tighten up the outher 12mm bolt... you now have tight belts and can do it singlehandedly too Quote Link to comment Share on other sites More sharing options...
