engine stand worries?
10 replies to this topic
#1 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 16 January 2006 - 09:47 PM
I was going to put my new engine on an engine stand so that I could start putting the accesories on from the old motor. A guy I was talking to said that it would be a bad idea to put an assembled aluminun block engin on a stand. He said that the aluminum isn't strong enough and I would end up cracking the bellhousing.
This sounds like a serious load of garbage, but having just dropped a little over a grand on this I just wanted a few opinions.
#2 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 16 January 2006 - 09:54 PM
Are you sing the same 4 bolts that attach it to the tranny? I wouldn't worry too much, just don't abuse it. My EA82 seems happy hanging on my engine stand... hadn't even considered that the stress would be too much.
#3 kayakertom
kayakertom
    Eat, Live, Breath Subaru
  • 329 posts
  • Lake Oswego
Posted 16 January 2006 - 10:01 PM
I've done it several times now without any problems. The longblock weight is around 250 lbs (110kg), so you really aren't stressing anything. It makes it so much easier to do the transferring pf parts. If you have any worries about your engine stand, use a bench with some wooden blocks under the oil pan until you are comfortable with the engine stand.
#4 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 16 January 2006 - 10:51 PM
I used a tire and pallet when I had to pull out the ea81
#5 Hodaka Rider
Hodaka Rider
    Original BC Soobnut
  • 1,577 posts
  • Nelson, BC (Canada)
Posted 17 January 2006 - 02:08 AM
Just tell him it's Japanese aluminum and metric bolts, and that it'll hold just fine.:rolleyes:
#6 BoostedBalls
BoostedBalls
    Subaru Fanatic!
  • 446 posts
  • Sacramento, CA
Posted 17 January 2006 - 02:46 AM
Mine has been sitting on the stand for a couple months now and I'm only using two bolts to hold it in place! I've torqued the heads, bounced it around over air hoses etc in my shop and it's still hanging with no worries.
#7 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 17 January 2006 - 02:48 AM
I've used my engine stand with 2 bolts (the top of the bell housing) and nuts on them... just finger tight.... then I slide the 2 studs on the bottom of the engine into the bottom of the 2 holes... I dont bother with nuts on those because the studs are too short to put a nut on with the current mounts on my stand.
Ive had EA82's and 81's on there with no, some or all of their accessories and never had a problem yet.
I HAVE on the other hand cracked a bell housing on an EA81 trying to use a breaker bar to keep the flywheel from turning so we could change the front main seal. We gave up and left it after it cracked... the seal wasnt leaking anyway. :rolleyes:
#8 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 17 January 2006 - 02:53 AM
I pretty much thought the guy was full of it, but wanted to hear from experience. Thanks guys.
#9 ballitch
ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 17 January 2006 - 03:06 AM
ya that guy was F.O.S. i have an EJ25 on the engine stand right now with top holes finger tight. been that way for 3 months now.
~Josh~
#10 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 17 January 2006 - 05:31 AM
2.7 on the stand for 6 months +. A couple of others as well.
Definitely FOS!
#11 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 17 January 2006 - 10:15 AM
I'd be really careful about any other advice the guy has for you, too.
