91 loyale brake light problems
Make sure that you have enough fluid in your master cylinder, you may be low, which is either a leak, or most likely you're pads are getting thin, and they need replacing, which if they do, we'll hit the junkyards and we can get some rear disc parts and do the rear disc swap at the same time.
It could also be that one of your brake lights are out, have Kim stand behind the car when you push the brakes, you might have a bulb out then.
