Front strut Q's
10 replies to this topic
#1 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 10 October 2003 - 11:36 AM
Are the front struts on an EA82 the cartrige style or a 1 pice? What about the EA81's and XT6's?
#2 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 10 October 2003 - 12:09 PM
EA82's have a McPhearson strut with a cartraige inside up front.
#3 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 10 October 2003 - 12:34 PM
COOOOOOOOOOOOOL!!!!!
#4 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 10 October 2003 - 02:11 PM
What is the atatchment? Do they screw in or clamp in? (the cartrige to the strut body that is)
I bet somone out there can tell where I'm going with this allready:-p
#5 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 10 October 2003 - 02:34 PM
uh... my cars dont have cartriges:cornfuzz:
both have complete strut assys. sealed.
they bolt onto the spindle assy and have a clamping bolt to tighten down on the strut housing.
what are your plans?
#6 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 10 October 2003 - 03:46 PM
Well...with cartrige stuts, when I do my lift I can make my oun NEW body for them insted of strut spacers. AND I can make the new body to use coil-over springs insted of the factory springs. The new body could be made from MUCH stronger stock than the OE units.
#7 StormTrooper
StormTrooper
    Eat, Live, Breath Subaru
  • 262 posts
  • Humboldt County, CA
Posted 10 October 2003 - 08:40 PM
design a housing that can accept more rugged struts, if possible (rancho, etc)
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 11 October 2003 - 09:54 AM
ea82 struts in an ea81? and by thus doing so, xt6 suspension pices?
i know how to do that, if i had all the parts!
#9 ByTheSea
ByTheSea
    1000+ Super USER!
  • 1,364 posts
  • Mass, USA
Posted 11 October 2003 - 10:06 AM
I measured a ea-82 strut tube at just over 2.0". You might be able to just cut off the botton section of tube with the bracket and use an insert type cartridge, designed for coilover applications, inserted into the resulting "cup".
#10 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 11 October 2003 - 10:30 AM
if you are using ea82 struts, you will need to modify the ea81 strut cap to fit them.
ir try getting ea82 knuckles to fit on the ea81 strut?
or do the whole ea82 lower control arm/axle/knuckle/strut swap, using xt 5lug and swaybar!
#11 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 11 October 2003 - 10:57 AM
Uhhh....thanks for the input Fox, but I am working on an EA82T wagon(gess I should have made that more clear:-p )
I gess if I need to I could just make the new body to use cartrige struts from somthing other than EA82.
