I have a 99 with auto transmission. The problem I am having is that trans fluid is coming out of the two top vent hoses. Of course the catalytic converter is right below and so it always has a faint smell of burning oil.
I never see any drips on the garage floor, the side of the trans below the hoses has oil on it. In the two weeks since I filled it there is no noticable loss of fluid but I can tell there is some loss just by the continued smell. ATF is not discolored and in great shape.
About 2 months ago after a 65mph drive in 95 degree weather there was a large loss of fluid and alot of smoke but since then no similar problems. The fluid and filter was changed a year ago when I purchased the car.
Should I go to a trans shop( I am afraid to do that) or try a dealer? Anyone have advice...or a similar problem?? What would be a best next step? thank you
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Forester transmission problem
Started by
ron2368
, Oct 11 2003 10:00 AM
5 replies to this topic
#1
Posted 11 October 2003 - 10:00 AM
#2
Posted 12 October 2003 - 10:14 AM
My 93 Legacy Auto just started doing the same thing as yours-LSG on another board knew what was up. Check your Trans-axel fluid level-If over filled with ATF-Then your front seal is leaking into your Trans-axel. Mine started comming out the overflow tube when the Trans-axel was way overfilled with ATF. My fix is to do front seal on Transmission($1,000) or find used one. Good Luck. Dave in Tahoe.
#3
Posted 14 October 2003 - 07:24 PM
I checked the gear box( the smaller dipstick on the opposite side from the atf stick) and the oil level was ok and there did not seem to be any contamination with ATF. So I still have no clue. I do not know any trans shops and so I will probably make an appointment at the Subaru dealer to get it checked.
#4
Posted 20 October 2003 - 08:15 PM
I checked the gear oil again and it was normal. What I did was replace thise short hoses with 2 longer ones and then ran the hoses into a plastic bottle that I secured in the engine compartment. The car has been used for a week, mostly short drives and the plastic bottle has no sign of ATF. The only thing I can see is that the front hose that is right next to the front edge of the trans housing has a sign that some ATF may have been in it.
Maybe that vent takes pressure off the front trans seal, anyone know?
#5
Posted 20 October 2003 - 11:58 PM
Next time look into a Subaru with a stick. I know that the clutch problems might put you off, but they appear to have been fixed--and Subaru was never known for its great auto trannies anyway.
#6
Posted 21 October 2003 - 03:31 AM
Sounds like you overfilled your transmission to me. I think all of them are made with overflow holes to prevent damage....
