83 locking diff
4 replies to this topic
#1 myshoeisonfire
myshoeisonfire
    New User
  • PipPip
  • 18 posts
  • Portland/Corvallis
Posted 23 January 2006 - 04:49 AM
Ive got an 83 ea81 wagon with 4x4 hi/low range - I was wondering if there is a way to weld the gears in the back, or otherwise lock the diff in the rear of the car?
I have never opened up a subaru rear end - I dont know if welding is even possible, or if its something i want to do. I just want something as close to a locker, or posi as possible, as i only use this car off road
thanks!
-Dan
#2 subarunuts
subarunuts
    USMB Regular
  • PipPipPip
  • 89 posts
Posted 23 January 2006 - 09:30 AM
Welding is pretty easy actually. Weld the spider gears to each other at each corner (4 welds).... I like to use a nice grade 8 bolt and jam it in the gears at the point where I make the weld. Never had one break yet. Don't weld the gears to the carrier as that is cast, and brittle. The gears are hardened, and will make a much tougher weld.
#3 1978 fj40
1978 fj40
    New User
  • PipPip
  • 23 posts
  • newtripoli pa.
Posted 23 January 2006 - 06:02 PM
can you weld it in the car ? also what did you use to clean off the gear oil ? what type of rod did you use ? thanks john
#4 subarunuts
subarunuts
    USMB Regular
  • PipPipPip
  • 89 posts
Posted 23 January 2006 - 06:09 PM
It can be done on the car, yes. It's best to remove it so you can be sure there are is no spatter left inside the diff before reinstalling. I used brake cleaner as it leaves no residue to clean the gears. Since I used a Lincoln 220v MIG to do the welding I could not comment on the rod type.
#5 1978 fj40
1978 fj40
    New User
  • PipPip
  • 23 posts
  • newtripoli pa.
Posted 23 January 2006 - 06:16 PM
thank you for your help, i have a 220 mig with gas that should work hate to go through the trouble to take it out have a good one!
