ej22 head interchange/ ej25 to ej22 swap.
4 replies to this topic
#1 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 23 January 2006 - 09:26 PM
Hi,
I've got a '98 Legacy OB 5MT (EJ 25) and am planning on swapping in an EJ22 for reliability. I gather that the '95 legacy ej22 is the best bet for easy bolt up...due to having dual port heads and EGR. Here's my question: would a dual port ej22 block from another year work OK assuming you changed the heads to the '95 version? In particular, I'm thinking of the earlier '91-'94 dual port engines.
Part two: the only reason to prefer the '95 over the '91-'94s is that the '95 has an EGR port, right? Has anyone simply defeated the EGR system and found a workaround so it doesn't trip the CEL?
Thanks,
Nathan
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,656 posts
  • East Coast
Posted 24 January 2006 - 08:40 AM
95 is the first year of EGR on the 2.2's but the last year of dual port.
if you use 95+ then swap the exhaust header as well and you're fine.
don't know about the EGR issue on older ones.
#3 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 24 January 2006 - 09:29 PM
Thanks!
Nathan
#4 MTRepair
MTRepair
    New User
  • Pip
  • 5 posts
  • Bozeman
Posted 18 December 2008 - 12:52 AM
One thing to think about. 95 automatics have the EGR, which you need if you want everything to talk to the 2.5 computer. 95 manuals do not have EGR. All 95's were dual port so you shouldn't have any trouble with the exhaust. 96 is when they swapped to single port. 90-94 blocks will work just fine if you have the 95 EGR heads.
Tim
#5 screwbaru2
screwbaru2
    Subaru Nut
  • 604 posts
  • hope valley
Posted 18 December 2008 - 04:31 AM
There is info here on drilling and tapping a non-egr head to make it egr compatible.
