Coasting in Neutral ?
10 replies to this topic
#1 SVX_commuter
SVX_commuter
    USMB Regular
  • PipPipPip
  • 96 posts
  • North Jersey
Posted 25 January 2006 - 02:19 PM
Has anybody with 4WD auto ever coasted in neutral with the engine running? What do you think of this? Will it damage the transmission?
Take care,
John
#2 zyewdall
zyewdall
    Subaru Master
  • 2,127 posts
  • Ward, CO
Posted 25 January 2006 - 03:10 PM
Well, I do in my manual tranny. I know they don't recommend it for manual or auto trannies, but obviously I don't listen...
#3 shaggywerewolf
shaggywerewolf
    USMB Regular
  • PipPipPip
  • 47 posts
  • Ann Arbor
Posted 25 January 2006 - 03:49 PM
Well Subaru warns against towing the car in neutral (AT) with all 4 wheels on the ground. Isn't coasting in neutral basically the same thing? If it is, I suppose if you do this repeatedly, you could damage the transmission over time.....
#4 ferret
ferret
    Subaru Nut
  • 650 posts
  • Northern NJ
Posted 25 January 2006 - 04:00 PM
Having had 5 speeds in all my Subaru's for 28 yrs, I have always taken the car out of gear and coasted up to Stop signs, red lights etc with no Ill effects.
As far as coasting in an Automatic, The only difference I see in the above statement between towing and coasting, is coasting with the engine running has the transmission front pump moving ATF thru the transmission thereby lubricating and cooling gears, clutches and assemblies. But I can't say if it will do any harm.
On the other hand, towing usually doesn't involve the motor running, hence miminal or no lubrication and no cooling.
#5 nipper
nipper
    Semi Elite Master of the
  • 17,110 posts
  • Long Island NY
Posted 25 January 2006 - 04:40 PM
Take care,
John
There are several reasons for not doing this, and none of them have to do with tranmission damage. You wont hurt the auto tranny by doing this. On a manual there is a chance that you may not be able to get the car back in gear.
If you do do this, you loose the benefit of engine braking on steep hills, and can over work the brakes. Not only that, if the hill is steep enough, you would be amazed as to how quickly the car can pick up speed. Also there are two ways to avoid an accident, use the big pedla or use the little pedal. If you have to make an evasive manuver that envolves the little pedal, you may act by instinct and forget the car is in neutral, and precous time is lost.
Beleive it or not, in most states it is illegal to coast in neutral (impossible to enforce unless they scrape you out of the car and see it in neutral).
nipper
#6 hooziewhatsit
hooziewhatsit
    I fix old cars
  • 1,323 posts
  • Klamath Falls
Posted 25 January 2006 - 04:52 PM
I used to coast occasionally, until I found out that if you coast in gear, with your foot off the throttle (throttle plate closed) the ECU will actually stop or inject less gas than if you were idling in neutral.
#7 SVX_commuter
SVX_commuter
    USMB Regular
  • PipPipPip
  • 96 posts
  • North Jersey
Posted 26 January 2006 - 12:18 PM
Yes I have heard that also, less gas with the throttle plates closed. What do you think about the engine braking effect? If this is true then the ECU must somehow figure out the engine is used being used for braking and tries to cut the gas to help it slow down. I wish I had a scan-gauge that measured mpg for car but it won't work on a 92. It would be an easy way to check on this.
#8 SVX_commuter
SVX_commuter
    USMB Regular
  • PipPipPip
  • 96 posts
  • North Jersey
Posted 26 January 2006 - 12:30 PM
nipper
Yes it is illegal in my state too. I have noticed an effect on coasting when a relatively simple mod is done. This is done by disconnecting the dropping resistor for the transmission line pressure. The tranmission does not allow engine braking to occur when this resistor is disconnected. This will allow the car to "free wheel" down the hills. So the car would not be coasting in nuetral for this "modification". Is there any other problems besides the power light (TCU) blinking all the time at start-up and the line pressure from the ATF pump at maximum all the time?
#9 2X2KOB
2X2KOB
    Subaru Fanatic!
  • 393 posts
  • Midstate MO
Posted 26 January 2006 - 02:06 PM
Why is it that you want to do this?
#10 zyewdall
zyewdall
    Subaru Master
  • 2,127 posts
  • Ward, CO
Posted 26 January 2006 - 02:17 PM
nipper
There are some long even hills on the freeway here that are the perfect slope to go down at 75 in nuetral. If I have it in gear, I have to keep my foot on the gas to keep the rpm's up at 3500 to keep it from slowing down. But that's a very special case. In general I agree, keep it in gear to use engine braking. As far as using the gas to avoid an accident, if there are other cars closeby, I usually don't do the coasting thing for that reason, though at that speed, an EA82 can't really accellerate anyway... :D
#11 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,289 posts
  • Houston, Tx
Posted 26 January 2006 - 07:18 PM
Just a note, don't ever cost with an automatic and the engine not running. The automatic trans get's its lubrication from the pump in the transmission. When the engine isn't running, it doesn't get lubricated.
As for your circumstance....personally, I wouldn't bother with putting the car in neutral.
