js grover Posted January 29, 2006 Share Posted January 29, 2006 Hey all: I have a 91 legacy, 2WD, 5-speed, with 240K on the engine (EJ22). Yesterday, the clutch began making a noticable skreech/vibration while engaging - espcially 1st and 2nd (but noise is there while shifting into all gears - just less so). Just pressing the clutch pedal do not create the noise. The noise is only while the clutch is engaging, the then disappears when the clutch is completely engaged. So the squeal lasts maybe 1 full second. The clutch does not seem to slipping at all - drives normally otherwise. Do you think this is just a worn clutch? Or some other bearing noise? This is a great site - thanks for your help! Quote Link to comment Share on other sites More sharing options...
2X2KOB Posted January 29, 2006 Share Posted January 29, 2006 Sounds like the clutch is worn, but I would expect some slipping to be evident, also. Any idea how many miles the clutch itself has? If it's 240k like the engine, I'd say that's a fairly respectable lifespan. Quote Link to comment Share on other sites More sharing options...
SubaruLegacy2003 Posted January 29, 2006 Share Posted January 29, 2006 Sounds like the throwout bearing. Change it when the clutch goes, no worries unless it get's really, really loud & hard to operate. I had a Honda that did this for 10 years & 150,000 miles before I had to do the clutch.... Quote Link to comment Share on other sites More sharing options...
