98 Legacy 2.5gt Mass Air-Flow Sensor signal wire help!
1 reply to this topic
#1 munkyenima
    New User
  • Pip
  • 1 posts
  • new mexico
Posted 12 October 2003 - 08:05 PM
I have a 1998 Legacy 2.5gt and I am trying to install the next level performance tri-phase module. Long story short, i need to know which of the 3 wires coming out of the Mass Air-Flow Sensor is the MAF signal wire. There is pink wire, a white wire, and a yellow wire with a blue stripe. Any help would be greatly appreciated!:confused:
#2 Dave K
Dave K
    New User
  • PipPip
  • 10 posts
  • Upstate NY
Posted 14 October 2003 - 01:22 PM
If you're doing internal work on any car it's just about imperatave to get a good manual. I have not modified either of my Soobs so I don't know what to recommend... but I'm sure you can ask around and get some imput.
I also don't know what the intended function of the "triphase module" is, but if it's a typical inexpensive bolt on that is supposed to enhance performance by changing the MAF signal to lean out the AF mix... it's not going to work. a 98 vehicle is OBD-II, and any tweak to the maf signal will quickly be corrected out in the block learn tables... if it's a big enough change it'll throw a code.
NOW... if this doohickey also intercepts the O2 sensors... well then it may be worth something, but I've yet to see a bolt-on that can scale O2 sensor input. (although I don't know what's out there for subaru's)
