Coolant temp sensor
9 replies to this topic
#1 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 31 January 2006 - 02:48 PM
93 legacy 2.2, and i need to replace the coolant temp sensor but not quite sure where it is. I've been looking all over the intake manifold but dont see it a little help would be great, (pics even better)
Thanks
David
#2 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 31 January 2006 - 04:07 PM
Thanks
David
If it's like on my 96 2.2 L, it's under the passenger's side rear intake manifold plenum. It's got two wiires connected to it and it screws horizontaly towards the front of the engine. You have to push aside or disconnect a few wires and vac lines to get access to it. Takes a ratchet and extension to take it off and replace.
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 31 January 2006 - 08:13 PM
yeah it's under the pass side intake manifold. here's a pic
http://www.main.expe...rs/DCP_2477.JPG
http://www.main.expe...rs/DCP_2476.JPG
#4 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 02 February 2006 - 12:14 AM
Thanks guys it I found it and replaced it but it didnt seem to fix the problem. Im starting a new post to see if some one can identify the problem.
David
#5 Eikari
Eikari
    USMB Regular
  • PipPipPip
  • 30 posts
  • Reykjavik
Posted 01 May 2006 - 05:56 PM
I´m now trying to replace the sensor and having a few problems.
1) How is the electrical connector disconnected from the sensor?
2) Do i have to take the manifold off to replace the sensor or can i just use a deep socket to get to it properly?
Thanks in advance
Einar
#6 a97obw
a97obw
    USMB is life!
  • 220 posts
Posted 01 May 2006 - 11:38 PM
I looked at the photos above in this thread, and if yours is like that one and mine being a burnt orange/red color then I'd suggest you grasp the male end of the connector (the end with the wires) between your thumb and forefinger and squeeze.....the $%$#^ thing has a "rocker" kind of operation that lifts the latch of the male end of the plug over the "barb" (note first photo above) on the female end and then pull the connector loose.
Sometimes I think that just figuring out how to undo the electrical connectors on a Subaru is the hardest part of any job!
And for the temp sensor, you might want to drain a bit of coolant from the system before you remove the sensor or from what I've heard you'll make a mess. (I haven't replaced mine, but I did disconnect it to remove the intake to do a head gasket job on my 2.5)
#7 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 04 May 2006 - 05:10 PM
Yeah....there's a connector that snaps onto a part of the sensor. You just push the connector part down, and pull/wiggle the connector off.
#8 Eikari
Eikari
    USMB Regular
  • PipPipPip
  • 30 posts
  • Reykjavik
Posted 05 May 2006 - 09:00 AM
But do you have to remove the intake manifold to replace the coolant temp sensor?
#9 frag
frag
  • 1,777 posts
Posted 05 May 2006 - 11:07 AM
No you dont. Just push aside some wires and hoses and use a ratchet extension.
#10 Eikari
Eikari
    USMB Regular
  • PipPipPip
  • 30 posts
  • Reykjavik
Posted 05 May 2006 - 01:02 PM
Thanks! :clap:
