MaroonDuneDoom Posted October 13, 2003 Share Posted October 13, 2003 i went to get some parts today, and while i was flipping a u-ie, my clutch cable snapped. i was wondering what all was involved in putting a new one under the hood? i'm sure i could figure out how to get it in the shroud and link it up, but i'm sure there's more to it. Quote Link to comment Share on other sites More sharing options...
Setright Posted October 13, 2003 Share Posted October 13, 2003 Well routing the cable is actually the hard part - especially hooking it up to the pedal...getting both hands under the dash and being able to see what you're doing aint easy on most cars. The adjustment should really be a piece of cake, unless you need to co-ordinate it with the hill holder, in which case it becomes a little more tricky, but not exactly difficult. I suggest removing the "initial pedal effort reduction" spring from the pedal assembly since this allows more play in the pedal movement. Getting it back on once the cable is taught can get aggravating but it's worth the extra ease of installing the cable in the first place. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 13, 2003 Author Share Posted October 13, 2003 i'm not sure if i have an initial pedal effort reduction spring. my pedal is just hanging limp. yeas, no. and is that the spring located just before the shroud on the pedal side, next to that little curved apparatus? oh, and this won't be real expensive, will it? Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 13, 2003 Share Posted October 13, 2003 I suggest removing the pedal from the mount... its alot easier to attach the cable to it that way. The hardest part in my mind was to get the 2 bolts on the mount for the cable in place... 1 is easy 1 is hard. The cable is only like $17 so it will take you 1.5 hours tops hopefully and be reasonably cheap Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 14, 2003 Author Share Posted October 14, 2003 i went to checker, because they offera 5% low price guarantee. i bought the cable, fiddled with it a while, finally got everything in it's respective hole, went to link it up and found that it was too short. i then went to my local subaru dealership and they said the earliest they could get one in would be next monday. should i just go to the junkyard and get one? would it be strong enough? i know it would be cheap. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 14, 2003 Share Posted October 14, 2003 Ok your car has 112K on it and the cable broke.... ummmm well think about it... most cars in the junkyard will probably have 50K more than your car... could you really trust that cable?? Its worth it to get a genuine subaru one... maybe use a junkyard one til the suby one comes in.... but get a new subaru one Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 14, 2003 Author Share Posted October 14, 2003 this guy i call santa, who gives me all kinds of free parts, came up w/a temporary one from a car that he stripped. i went ahead and ordered the one from subaru. one thing that i figured out from "santa" that everyone else neglected to tell me was that when installed, the pedal needs to have about an inch of "play" before it engages. this is so some bearing doesn't spin all the time. probably just slipped your minds, but thats the kind of stuff i was looking for in my original post. but thank you all very much for the help and advice. take it easy:wave: Quote Link to comment Share on other sites More sharing options...
