engine pinging/knocking problem with EA82
20 replies to this topic
#1 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 13 October 2003 - 12:09 PM
I have a 1991 Loyale EA82 (Canadian car) that has a terrible pinging problem that is driving me crazy! This is what happens.
The problem predominately exists when the outside temperature increases. I bought the car in the winter and did not know of the problem until it reached over 15 degrees Celsius (60 Fahrenheit) the following summer. The hotter it gets, the worse it gets. The problem happens often but not consistently. The more I drive the car the better it gets. There will be times that I don’t hear anything for an hour (on the highway) and then I will slow down for an exit and when I accelerate again, the motor sound like it is coming apart. I’ll take my foot off the gas and accelerate once again and no more pinging/knocking.
These are the things I have done to try and solve the problem.
1. Replaced O2 sensor
2. Replaced radiator (it was starting to overheat)
3. Replaced coolant temperature sensor (improved throttle response but not pinging)
4. Cleaned little "pick-up wires" in Airflow meter (intake track)
5. Timing is at 16 degrees BTDC. If I set it at the recommended 20 it is worse. At 16 degrees the car is noticeably sluggish.
6. Recent tune-up with NGK V-grove plugs, cap and rotor. I also purchased an Accell Super Stock coil but it basically left me on the side of the road the next day (ignition would cut in and out, would stall at idle – old coil is back in and working fine).
At this point I'm totally lost! I can unplug the O2 sensor but there is no difference except throttle response goes to hell. I must run high octane fuel 91 or it is considerably worse. My Subaru guru told me that he has seen this time and time again in Loyale’s from 1990 to 1992. There seems to be a design flaw with these years. My questions for the group are:
1. Can anyone confirm the 1990-1992 problem that seems to plague EA82’s?
2. Can anyone suggest something to me that I may have not thought of?
Thanks so much,
Matt
Lethbridge, Alberta
#2 SovereignMK
SovereignMK
    New User
  • PipPip
  • 28 posts
  • Spokane WA USA
Posted 13 October 2003 - 12:28 PM
I get pinging in hot weather if I run anything less than Premium on my 86 Wagon(EA82). Going to find out if it's true for cold weather as soon as it gets here.
#3 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 13 October 2003 - 12:34 PM
Thanks for the info. I'm currious to know what you find out.
Matt
#4 subynut
subynut
    EJ Powa!
  • 1,422 posts
  • Sierra Vista, AZ
Posted 14 October 2003 - 02:31 AM
Knock sensor?
Justa thought
#5 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 14 October 2003 - 07:17 AM
I don't believe the EA82's (non-turbo) came with a knock sensor. If they did please let me know where it is located.
Thanks,
Matt
#6 Nug
Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 14 October 2003 - 07:25 AM
Check the function of the EGR valve. Make sure it isn't plugged w/carbon and that vacuum gets to it.
#7 Guest_taprackready_*
  • Guests
Posted 14 October 2003 - 11:07 AM
We have a 93 Loyal at work, and it has the same problem. It also has the check engine light on all the time. Took it to a sub dealer and they were not able to fix either problem. We just run premium in it and put black tape over the check engine light. They said the light had to do with some minor function that didn't effect the overall performance of the engine. So much for taking a vehicle to the dealer.
Bill
#8 SovereignMK
SovereignMK
    New User
  • PipPip
  • 28 posts
  • Spokane WA USA
Posted 14 October 2003 - 12:10 PM
Oooo, Have any pics pointing that one out? Is it like the PVC valve? Rookie here, needs a map around the engine bay.
//M
#9 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 14 October 2003 - 01:08 PM
Hey Matt
It could be a sticky vacuum advance mechanism that’s not retarding properly at low vac (high throttle). The advance plate rides on a large diameter ball bearing that can get loaded up with crap. I had a pretty severe interment detonation problem pulling hills with my ’87 GL, I tore the distributor down, cleaned and relubed it (also replaced a bad bushing on one of the mechanical advance weights) and that solved the problem. Worth a try.
Gary
P.S. Hope you had a great Thanksgiving.
#10 Nug
Nug
  • 1,968 posts
  • West Point, VA
Posted 14 October 2003 - 02:31 PM
Someone post a pic of an EGR valve for this fine sir. I don't have a pic of one. Don't even own a sube, for that matter...
#11 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 14 October 2003 - 02:50 PM
The EGR valve is on the back side of the intake manifold. It's got a big round vacuum diaphragm on it.
Run a bottle of Chevron Techron through it, should help. Also, when you set your timing, you disconnected and plugged the vacuum advance right?
20 degrees seems awful high, mine is supposed to be 12 degrees I beleive (EA82T)
#12 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 14 October 2003 - 08:37 PM
Thanks for the idea but the newer models do not have a vacuum advance system or weights to control advance.
Matt
Originally posted by All_talk
Hey Matt
Gary
#13 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 14 October 2003 - 08:42 PM
I know that the vacuum to the EGR is good but I do not know if it pulling EG back or if it is just plugged at the bottom. 20 degrees is spec for the newer models. Their is no vacuum advance on the newer style distributors (crank angle sensor type distributor).
Thanks,
Matt
#14 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 14 October 2003 - 09:46 PM
the egr will not make you ping!
it will run fine withoug an egr at all.
look elsewhere.
#15 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 15 October 2003 - 02:12 AM
hmm.. Maybe for some reason the computer is not adjusting the timing properly?? Put a timing light on it and rev the engine up, you should be able to see the timing advance itself.
I also remember hearing that there are two connectors you are supposed to hook together before setting timing??
To test the EGR valve: At idle, reach inside the diaphragm housing on the EGR valve and lift the diaphragm up, this will open the EGR valve. If the car starts to stumble (it might die even) then the EGR is working, if it does not stumble, then your passage could be blocked, or the valve stuck open (will idle rough with it stuck open) without EGR, the combustion temperature will rise, which CAN cause pinging (overly hot chamber leads to pre-ignition, fancy word for pinging).
#16 Nug
Nug
  • 1,968 posts
  • West Point, VA
Posted 15 October 2003 - 06:26 AM
The EGR valve dilutes the incoming air/fuel mix with inert exhaust gas, effectively taking up space, and therefore lowering combustion temps.
How about excessive carbon in the combustion chamber? Anyone recommend a top engine cleaner or the 'water trick'?
#17 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 15 October 2003 - 08:06 AM
Thanks for the instructions on how to test. I'll try it this weekend.
Matt
#18 mnorton
mnorton
    New User
  • PipPip
  • 11 posts
  • Alberta
Posted 15 October 2003 - 08:07 AM
I would be very surprised if there is excessive carbon in the cyclinders. I run the old beast pretty hard and the plugs do not have any carbon deposits on them.
Explain the water trick!
Thanks,
Matt
#19 KStretch55
KStretch55
    Subaru Fanatic!
  • 370 posts
  • Boise County
Posted 01 April 2005 - 02:52 PM
Do a search for "water trick". I tried it last night in my '92 Loyale.
#20 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 01 April 2005 - 04:14 PM
Heres what cured mine: (1) new oil pump; (2) run 10w30 in it; (3) new oem pcv valve; (4) do the full Seafoam treatment (suck it in the top, add to gas, add to oil per directions on can), (5)new plugs/wires/rotor/coil. If I had to guess which of the above are most important with respect to ping at high outside temp and under load? I'd go with (1) and (4).
Timing: My mechanic swears by 18 rather than the stock 20 for the 1.8 spfi. Works for me.
#21 Petersubaru
Petersubaru
    1000+ Super USER!
  • 1,091 posts
  • Sarnia Canada
Posted 02 April 2005 - 11:32 AM
What I found worked for me was to first change the spark plugs to one set colder and if they don't foul up on you, all is fine...then I changed the thermostate to 160deg..(my rad is new so the coolant runs very freely thru it)(don't forget to drill the small hole on the thermostate flange)..set the timing to 18deg.at the proper rpm. and us 89 octane gas...if you ever get around to changing your headgaskets, cleaning up the heads will make big difference..
