Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
left and right ea82 heads same?
Started by
archemitis
, Oct 13 2003 02:23 PM
9 replies to this topic
#1
Posted 13 October 2003 - 02:23 PM
im looking at two ea82 heads, one left and one right. they look like they could go on either side, except for the egr. they seem to be the same casting.
#2
Posted 13 October 2003 - 02:24 PM
these are spfi heads
#3
Posted 13 October 2003 - 03:37 PM
Ya, other than the EGR I belive they are identical.... I know for a fact that the head gaskets are identical on SPFI's
#4
Posted 13 October 2003 - 03:42 PM
The castings are identical, but the machining is different. You can bolt either head on either side.
I know because I have done it wrong before....
#5
Posted 13 October 2003 - 04:16 PM
so, i might as well go to the junkyard and get a head from the cold side(drivers) and it shouldnt be cracked as bad as all the hot side ones, and it wouldnt have that damn hole for the egr. this is a revelation to me, cuz i was looking for an uncracked passenger side head for a long time.
#6
Posted 14 October 2003 - 06:16 AM
HUH! What about the Dizzy drive on the l-hand head? The longer valve cover that requires 5 bolts rather than 4? We really talking EA82 here?
#7
Posted 14 October 2003 - 07:17 AM
Sorry RedRX, but the cam holder assembly bolts onto the head the same way on both sides and is not part of the actual head. The EGR hole can be plugged. The only heads that I know of that are truly right and left are the turbo head, and that is only because of the oil passage and the water return being machined in the passenger (right side) head.
What crack are you talking about. If it is the crack between the valves, that is very common, and if small, it is really not a problem. If it gets larger, it could cause the valve seat to fall out. It is the crack in other places on the head that are a problem.
#8
Posted 14 October 2003 - 08:18 AM
i know its cool to use the heads with cracks between the valves, but i have one that got real hot, and the crack on the passenger side head is eroded, and large.
i bead blasted it to reveal it was cracked under the valve seat too, so i want to get a better one.
and since there was never a hold drilled for egr, it should mean better flow, without that pocket of dead air right outside of the combustion chamber.
#9
Posted 14 October 2003 - 04:42 PM
i just blasted two more heads, and they all have cracks between the valves, and even the small ones go down behind the valve seat and into the port. damn weak... might have to tig the crap out of them.
#10
Posted 19 October 2003 - 05:34 AM
DOH! - for some reason I was thinking cam-boxes rather than heads.
