gear ratios??
6 replies to this topic
#1 Meeky Moose
Meeky Moose
    Subaru Master
  • 2,332 posts
  • Grants Pass
Posted 14 October 2003 - 10:13 AM
is there a difference in gear ratios in a 5-speed d/r and a 4-speed d/r?
#2 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,109 posts
  • Sumner
Posted 14 October 2003 - 10:26 AM
There shouldn't be unless it is a FT4WD or from an RX. If it is it will have a 3.70 final ratio. The gear to gear ratio's are different. 1st gear is similar and they basically fill the gaps between the rest of the gears.
#3 AKIRA
AKIRA
    USMB Reverend
  • 614 posts
  • Jersey Shore (Central) PA
yes there are, but I don't have the doc. on this computer, I will post it later.
#4 Qman
Qman
  • Moderator
  • 11,109 posts
  • Sumner
Posted 14 October 2003 - 10:34 AM
Here's a link from one of the numerous gear ratio posts.
post
There's more info on this. Do a search for gear ratios in all open forums. 1+pages of responses.
#5 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
If you are speaking of gearing for each individual gear then you are correct..
but for final drive ratio and rear diff ratio, Qman is correct.
normal 5spd DR(read non RX) is 3.90, as is the 4spd DR
#6 Meeky Moose
Meeky Moose
    Subaru Master
  • 2,332 posts
  • Grants Pass
Posted 14 October 2003 - 11:10 AM
yeah i was speaking in terms of individual gears, thinkin maybe a 5-speed has lower gearing in 1,2,3 than the 4-speed does... as the hatch is now ya can't get it into 4th gear until your doin 70+.. and if a 5-speed has lower gearing in the 1,2,3 then that would be better for offroading anywho...
#7 StormTrooper
StormTrooper
    Eat, Live, Breath Subaru
  • 262 posts
  • Humboldt County, CA
Posted 14 October 2003 - 11:14 AM
not sure why, but it has been suggested to use the 4sp. D/r for off-roading
