GeneralDisorder Posted October 14, 2003 Share Posted October 14, 2003 I think one of the reed valves has gone in my Brat. It was really hard to start when cold, and I took a look, and there was a couple big peices of melted plastic blocking the choke open. I removed those, and she seems to be running fine now - back to normal I would say, so I don't think the plastic hurt anything other than keeping the choke from closing. It looks like the plastic was already hard by the time it reached to carb. Anyway - what should I do? I could replace the AIS valve - should I do both at the same time, or just the bad one? Or maybe should I just remove them completely? I like the idea of removing them, but will I still pass emmisions? And how difficult is it to block off their passages if I should decide to give em the boot? Also - if I remove them, I know it will affect the ability of the cat to work correctly, but by how much? If I remove them should I remove the cat too because it really isn't doing anything without the AIS system.... or will it still function to a degree? GD Quote Link to comment Share on other sites More sharing options...
edrach Posted October 14, 2003 Share Posted October 14, 2003 We had a big discussion about that valve in the past. I hope it's still in the archives. You can buy a replacement valve with the newer style body for about $17; open it up, take out the reed valve portion and put it in the old body. Also, check the local pull a part yard to replace the plastic pieces. You need to replace that also since now you're pumping exhaust gasses into the underhood area; it's not nice stuff to be breathing while you're driving. Give me a call and I'll try to get the part number of the valve for you. Rick, here's the link: http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=2569&highlight=air+suction+valve Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 14, 2003 Author Share Posted October 14, 2003 Yeah - I have been driving with the windows down - it does indeed smell pretty nasty in there. I thought maybe I had an exhaust leak or something, but when I found the AIS valve, I figured that was probably the source of my smell as well. I don't think the plastic silencers have melted tho - unless they melt from the inside or something - outwardly they look fine anyway. I have to drive it till I get my wagon back, so I hope it doesn't melt them in the meantime - I've been driving it this way for a week or so, and just now had the time to take a look. It ran fine when warm, so I figured maybe the choke was malfunctioning, and put off looking into the problem longer than I should have probably. Hopefully any peices of plastice that made it into the intake didn't hurt anything. I guess they would just melt, and be thrown out the exhaust anyway. I remember that big discussion we had - it did make it into the archives as I recall - I'll try to find it, and post the part number from there. GD Quote Link to comment Share on other sites More sharing options...
edrach Posted October 14, 2003 Share Posted October 14, 2003 The plastic parts do seem to melt from the inside. You might put a screen over the intake of the carb to keep from swallowing any more chunks of plastic. This cost my son a carb re-build since the plastic got in deep enough to prop the throttle open and over rev the engine. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 14, 2003 Author Share Posted October 14, 2003 Yeah - I consider myself lucky to have caused as little mayhem as possible in my carb - seems to run just fine still. I think I will go put the screen on it anyway - leave it there for good I think maybe. GD Quote Link to comment Share on other sites More sharing options...
