Can a 2.5 OB be converted to 2.2?
9 replies to this topic
#1 soldierrsb
soldierrsb
    New User
  • Pip
  • 2 posts
  • MO
Posted 14 October 2003 - 08:22 PM
I have one of the trouble prone 2.5 , in a 97, 5 Speed. OB which is on it's second HG @ 150K miles. I just purchased an older, 91 legacy, with a strong 2.2 engine and a weak Auto Tranny. How difficult would it be to put the 2.2 in the 97 OB?
Will the flywheel from the 2.5 fit the 2.2? Could I use the OB ECU or would I have to change the wiring and ECU from the legacy to the OB?
Any assistance would be appreciated. I've owned subaru's for years, from the 1.6 to this 2.5 and this is the most troublesome engine of all. I normally average over 200k on a subaru engine with normal maintenance.
Thanks
Soldier Bob
#2 johnd911
johnd911
    USMB Regular
  • PipPipPip
  • 118 posts
  • Buffalo
Posted 14 October 2003 - 10:09 PM
My 93 legacy has 327,000 and is still going strong. After all that I have read here about 2.5"s forget it. When it comes time to replace my current legacy, HG replacement at 100k will not do. What years were 2.2's still around after 93 and in what models. thanks I may even look at other makes. For someone who has had subarus past the 300,000 mile point many times, this HG BS on 2.5's will not do.
#3 Commuter
Commuter
    Subaru Master
  • 1,857 posts
  • Niagara area, Ont Canada
Posted 14 October 2003 - 10:49 PM
I recall Emily of CCR Inc saying that some people were putting 2.2's in the Outbacks. Apparently it's not a big deal. Same ECU and wiring harness IIRC. You might want to give them a call.
Commuter
#4 sprintman
sprintman
    USMB Regular
  • PipPipPip
  • 105 posts
  • Canberra Australia
Posted 15 October 2003 - 12:04 AM
Are the 2.5 engines made or assembled in the US or imported whole from Japan?
#5 ballitch
ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 09 December 2004 - 07:47 PM
If im not mistaken, you have the DOHC 2.5? If so then hmmmm..... If it is SOHC then u can throw in older legacy's motor and call it good. But if it's DOHC you'll have to put in older legacy's ecu also, you might......i mean might, have to change a couple of pin outs if it is an AT ecu into your 5 speed OB, and vice versa. or if some of the sensor pin out locations changed from model year differences. Someone back me up or call me F.O.S.
~Josh~
#6 Subarunation 713
Subarunation 713
    Eat, Live, Breath Subaru
  • 284 posts
  • Bridgman (SW Mich)
Posted 10 December 2004 - 03:33 PM
~Josh~
I bought a 97 OBW with auto and a bad 2.5 (broken timing belt). I am thinking about taking a 2.2 out of a 95 Legacy auto and dropping it in.
I bought it to sell, but if I can get a 2.2 and put it in the 97 easly enough I might drive it to death instead.
Somebody out there has had to have done this 2.5 to 2.2 swap before. Are we nuts or will it be fine?
The 2.2 was used as late as 2001 on the Impreza and as late as 99 in the Legacy L and Brighton.
#7 outback_97
outback_97
    Eat, Live, Breathe Subaru
  • 655 posts
  • SLC, UT
Posted 10 December 2004 - 06:19 PM
Dr. Searchlove, or How I Learned to Stop Worrying and Love the Search:
http://www.ultimates...ghlight=2.2 2.5
Steve
#8 gsrxrsx68
gsrxrsx68
    New User
  • PipPip
  • 21 posts
Posted 10 December 2004 - 06:54 PM
So is that correct that ECU's need to be swapped if the engine is DOHC?
#9 ccrinc
ccrinc
    The Subaru Whisperer
  • 1,028 posts
  • Denver, CO
Posted 10 December 2004 - 07:09 PM
The 2.5 DOHC conversion to a 2.2 is quite simple. You must use a '95 EJ22 in order to get the exhaust to match up. You do not have to change the ECU. You need the '95 intake manifold.
Emily
http://www.ccrengines.com
#10 Gnuman
Gnuman
    1000+ Super USER!
  • 1,399 posts
  • Richmond, CA
Posted 10 December 2004 - 09:32 PM
Emily, can you tell me more about the EJ27 XT6 OHC 6 cylinder engine, and how well it would fit in a 92 Legacy that came with an EJ22 (n/a)? Are there any weaknesses in that engine that would make it a bad choice for an upgrade? I'm looking at years down the line when my EJ22 crosses the half mil mark, but I will be wanting something solid at that time as well. . .:D
