EA81t intake manifold/head port size mismatch..
3 replies to this topic
#1 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 12 February 2006 - 04:23 PM
Just thought i'd share this, it probably applies to all ea81s, but i can only vouch for it applying to ea81ts........
I noticed the spare intake manifold i had had been ground out, quite a lot, mainly on the outside radius of the bend. Then i noticed that the head i got with it had not been touched. Now why would you port the intake manifold and not the heads???
Because, the holes in the heads are at least 2mm larger in most directions than the holes in the intake!!!! Yuck. The subaru gaskets are smaller still.
I've ended up using the ported intake, and i cut down the gaskets to match with a dremel.
Something worth thinking about if you've got your intake manifold off.....
#2 scrap487
scrap487
    Certified Subaru Nut
  • 989 posts
  • Government Camp
Posted 30 June 2006 - 05:42 PM
only if this was posted yesterday... sigh :rolleyes:
er I mean only if I saw it yesterday... posted in january doh
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 30 June 2006 - 05:53 PM
Probably does not apply to the EA81 N/A - the T heads are quite different. For one, they have injector boss's where the NA ones do not. Different casting.
#4 carfreak85
carfreak85
    Temple of Fuji
  • 5,297 posts
  • Cascadia
Posted 30 June 2006 - 08:39 PM
Actually it probably does apply to N/A EA81s. Maybe not in all directions as with the turbo manifold, but I can say personally that the EA81 carby manifold is poorly cast and would benifit from some port matching.
