muskalope Posted October 16, 2003 Share Posted October 16, 2003 Hi all - Looking for some coaching on my 91 Legacy wagon. It's got about 140k miles, original owner. I get some wobble in the front end at freeway speeds, which is annoying. It gets solid once brakes are applied, or below the freeway speed. Would this be probably ball joints, or would it be tie rod ends? I'm assuming whichever it is, the car would require an alignment after the part replacement, right? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 16, 2003 Share Posted October 16, 2003 Jack up the car and see if the wheels wiggle perpundicular to the car. That will tell you if its wheel bearings or ball joints. If there is some play look at your bal joints when you wiggle it. If you see them wiggeling too and they look shot... well its ball joint time. If its wiggeling and the ball joints look fine its bearings. It could be some other things but this is a very easy test to start with for trouble shooting this issue. Thanks Quote Link to comment Share on other sites More sharing options...
Legacy Posted October 16, 2003 Share Posted October 16, 2003 When I first got my 91 Legacy, it had warped rotors, and I replaced those to cure the braking wobble it had. From the previous owner's maintenance records I found that the front end had been fixed up a couple of years prior and I still have a slight wobble at high speed. I always figured it was the rims going more and more out of round with time and the pounding they are subjected to. The tires aren't too bad, but they don't have too much life left in them, so they probably aren't quite balanced either. Just some extra thoughts I thought I'd share with you... Quote Link to comment Share on other sites More sharing options...
muskalope Posted October 17, 2003 Author Share Posted October 17, 2003 Thanks for the advice. Tires are brand new, as well as the brakes. With this happening, I figured I'd taken out a few of the variables for the problem. I'll check the bearings and the ball joints this weekend. I'm figuring that since the car has 140k miles, and neither the bearings, ball joints, or tie-rods have not been touched since new, I may just do them all, and get them up to snuff. I'll give an update once I learn the issue. Quote Link to comment Share on other sites More sharing options...
jcniest5 Posted October 18, 2003 Share Posted October 18, 2003 Mine does the same thing as stated here. Rotating tires doesn't help so I think it's either bearing or ball joints worn out. I just drive it with the little annoying. Quote Link to comment Share on other sites More sharing options...
ScoobySchmitty Posted October 21, 2003 Share Posted October 21, 2003 I have the same problem, only it will be wobbling for a mile, then off for a mile, then wobbling...etc. you get the idea. It does not bug me much, but I believe i will need to replace the b-joints and bearings soon, a job I am NOT looking forward to. ScoobySchmitty:banana: Quote Link to comment Share on other sites More sharing options...
