iayers Posted October 16, 2003 Share Posted October 16, 2003 (i would have thought this issue was already discussed on the board, but couldn't find it... sorry if this is a repeat...) SO. I get a distinct rattle when I and turning tightly, and I drive at a SLOW speed over a sharp edge (say, a lip of a parking lot, or grate, etc....) I have a 99 outback wgn with 103k miles. I feel the rattle in the steering wheel (reverberates for a second after you hit the bump). And it can be heard, as a muffled low frequency rattle coming from the front of the car. I actually got to demo it to a Subaru mechanic, he noticed it. He said that it was the steering coupler (or something like that). And that it is common and has no detrimental effects. I'm fairly certain that this is not anything loose, it's not bearings, and it's not CV related. It only happens during tight turns, and I only notice it when going slow, as in under 20 mph. What is this? Was the mechanic right? Is this bad? Thanks. There are some really knowledgeable people on this board, it's awesome. Such a big help. Quote Link to comment Share on other sites More sharing options...
WAWalker Posted October 16, 2003 Share Posted October 16, 2003 There is a TSB out on this. So yes it is common. There isn't anything wrong, but in order to fix the noise a steering u-joint with damper needs to be installed. P/N 34160AC030. I would attach a copy of the whole TSB but I can't find it at the moment. Quote Link to comment Share on other sites More sharing options...
iayers Posted October 17, 2003 Author Share Posted October 17, 2003 excellent... about what range of prices will a mechanic charge to install the new dampened u-joint part? i saw the part listed on 1stsubaruparts.com for about $90. how invasive is the install? is there a guide someone wrote up somewhere? I noticed the part WAWalker listed is for the legacy model. i found an article that lists a specific part# for the outback: 34160AC090. or does the 34160AC030 part # do the trick for legacy outbacks as well as legacys? thanks Quote Link to comment Share on other sites More sharing options...
WAWalker Posted October 17, 2003 Share Posted October 17, 2003 Sorry, the other part number is the one for an Outback. Flat rate is .6 hours to replace. Quote Link to comment Share on other sites More sharing options...
