tjdrury Posted October 17, 2003 Share Posted October 17, 2003 Hey everyone, I'm in the middle of swapping my composite headlights for the quad sealed beams. The physical part is done, but I'm having problems w/ the wiring. Is there anything I need to change about the wiring to get it to work properly? I've tried a couple combinations of swapping wires around but always have something not right. Now w/ the low beams on the highs have a really dim glow. Any help would be greatly appreciated. Thanks, Quote Link to comment Share on other sites More sharing options...
tjdrury Posted October 18, 2003 Author Share Posted October 18, 2003 bump Quote Link to comment Share on other sites More sharing options...
subynut Posted October 18, 2003 Share Posted October 18, 2003 blown fuse? When I re-wired my headlights, I pulled one of the fuses (just out of curiousity) and I had that similar problem. Mine uses a common hot system. All the wires are hot when the lights are off and key on. Then one goes to ground when you turn them on. Low beams on: Low beam: low; High beam: high; Return: high High Beams on: Low beam: high; High beam: low; Return: high Hafta go out and check which wires are what. What's da year/model/etc? Specs would be helpful! :cornfuzz: :wave: Quote Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted September 22, 2005 Share Posted September 22, 2005 Hey tjdrury Just curios how that headlight conversion went? Quote Link to comment Share on other sites More sharing options...
edrach Posted September 23, 2005 Share Posted September 23, 2005 Save yourself a lot of grief and rewire the lights using relays and run the 12V for the lamps directly off a fused line to the battery and fresh ground returns. Then use the socket of the existing wiring to turn the relays on and off. If I can find it, I'll post the link to a wiring diagram (it was posted here at one time; might even have been the ezboard it was so long ago). Good luck with it. Quote Link to comment Share on other sites More sharing options...
