Loyale Headlights won't go off
6 replies to this topic
#1 Subi
Subi
    New User
  • Pip
  • 5 posts
  • Bethlehem
Posted 26 February 2006 - 02:42 PM
I have a "new" Subarau Loyale stationwagon, and the headlights won't turn off while the car is on.
In the off position, the headlights are on, but the inside gauges are not lit up. In the dim position, the headlights are off, but the low level dim lights are on and the gauges are lit up. In the on position, the headlights are on like in the off position and the gauges are lit up. The high beams also work. The only problem is that I cannot get my headlights to turn off while the car is on. If this were a new car, I'd figure it was supposed to do that, but it's a a trusty Loyale and I suspect this should not be happening. Does anyone have suggestions? Thanks.
#2 Subaru Jim Maple Ridge
    USMB is life!
  • 176 posts
  • Maple Ridge, BC, Canada
Posted 26 February 2006 - 02:59 PM
Sounds like somebody wired the low beams as daylight running lamps, or your car was factory that way. Don't worry, lots of people don't bother to tell us what year or model we are dealing with, just expect us to make wild guesses and waste space. Doesn't sound like you have a problem anyway, DRLs are just a safety thing, like seat belts, bumpers, signal lights etc.
#3 Numbchux
Numbchux
    EJ conversion addict
  • 6,889 posts
  • Saginaw, MN
Posted 26 February 2006 - 05:47 PM
yea, I can't think of a way that it would do this accidentally. it sounds like someone did it on purpose. but the loyale's did not come with DRL's from the factory.
#4 Hodaka Rider
Hodaka Rider
    Original BC Soobnut
  • 1,577 posts
  • Nelson, BC (Canada)
Posted 26 February 2006 - 06:10 PM
Actually, they did. I've got two of them. It may have been only a Canadian thing (required by law here since '89 or so), in which case his car might also be from Canada, or parts of it.
#5 moosens
moosens
    Vintage Subathusiast
  • 2,015 posts
  • Bridgeport CT
Posted 26 February 2006 - 07:11 PM
Right,I know in the Maritimes it's needed,probably the same out west....you turn a corner and there's a sudden fogbank thick as can be.Good law.But,you'll buy headlights every couple of years.
#6 Numbchux
Numbchux
  • 6,889 posts
  • Saginaw, MN
Posted 26 February 2006 - 08:24 PM
huh....good to know
#7 stephenw22
stephenw22
    Certified Subaru Nut
  • 877 posts
  • SK, Canada
Posted 27 February 2006 - 12:58 PM
In Canada, daytime running lights have been required on all cars 1990 and newer.
It sounds like yours aren't factory DRLs, at least not the Canadian style. My '92 Loyale has the headlights on all the time. In the 'off' and 'dim' position, the headlights are on, but they are dimmer than when the switch is in the 'on' position.
Also, pulling the e-brake with the switch in 'off' or 'dim' will turn the headlights off (good for when you're at the drive-in on a cool night).
