What else can I take off a parts car?
13 replies to this topic
#1 Guest_unix_*
  • Guests
Posted 23 July 2003 - 08:54 AM
'92 Loyale SW.
Thus far I got:
EA82 (of course)
AC compressor (might just keep it, not install it)
All the nuts and bolts I got in the process of engine removal.
One full size wheel substituting the spare
Exhaust - the entire thing from exhaust flanges to the muffler, including the catalytic converter
I can't keep this car for some future repairs I need to remove as much as possible now.
What about gas shocks, do I need those? My car has 180K miles on it, the parts car only 90K.
#2 Guest_Wagon Wagon_*
Guest_Wagon Wagon_*
  • Guests
Posted 23 July 2003 - 09:14 AM
You can always do what Paul (moosens) did, and chop the whole car into 3 foot long, 1 foot thick sections and hang it on your garage walls. :rollin:
If you have the storage space I'd say pull everything removable off that car. You never know what you'll need. And if you need cash sometime, you could probably sell some of it.
#3 Guest_toybuilder_*
  • Guests
Posted 23 July 2003 - 09:20 AM
Get the fuel pump.
Also get the ECU and all the relays that are near it.
#4 Guest_calebz_*
  • Guests
Posted 23 July 2003 - 09:34 AM
Ballast resistor for the HVAC fan
#5 Guest_unix_*
  • Guests
Posted 23 July 2003 - 01:40 PM
Problem is, I don't have the storage space. I cannot store anything other than alternator-sized parts. I have to get rid of the rest of it. The rest is available - the interior and the transfer case, tranny (not shifting out of 1st), and so on.
I can part it out or sell it whole. It is in Virginia. (see my post in Market place)
#6 Guest_GlCraigGT_*
  • Guests
Posted 23 July 2003 - 02:46 PM
get the axles, if you don't have room, make room or hang them from the rafters.
Also get the brake calipers, rotors and hubs
#7 Guest_unix_*
  • Guests
Posted 23 July 2003 - 04:08 PM
I have 180K on these axles, when should I expect them to wear out?
Is it hard to remove the rotors? The ones I have need to be turned and the garage said it is easier to turn them on the car without "disassembling the front end".
By hubs, you mean the wheels? Why would I have any use for them?
What about the ball joints?
#8 Guest_Struculeus_*
  • Guests
Posted 23 July 2003 - 04:41 PM
I would also take off the side mirrors, headlight casings, and radio, if they're salvagable. You can sell them for a bit o' dough on E-Bay.
#9 Guest_unix_*
  • Guests
Posted 23 July 2003 - 05:44 PM
Ebay is a good idea, I think I will put the whole thing on there.
My post in Marketplace
#10 Guest_WagonsOnly_*
  • Guests
Posted 24 July 2003 - 12:07 AM
Don't forget tail lights, side markers, exterior trim and roof rack if there is one. And try to save the carpeting, turn-signal stalk and door handles/window cranks if they're not too badly sun damaged.
I wouldn't bother with the axles if they're original at 180k unless the car was driven very gently.
Just my .02,
#11 Guest_unix_*
  • Guests
Posted 24 July 2003 - 07:35 AM
My Loyale has 180K on the axles. The donor car I am taking stuff off has 93K miles.
#12 Guest_Snowman_*
  • Guests
Posted 24 July 2003 - 08:06 PM
Definitely get the axles if they look good. If you want to make some money, grab any trim pieces interior or exterior that are in good shape and sell them.
#13 Guest_unix_*
  • Guests
Posted 25 July 2003 - 09:37 AM
The axles look good. But if I remove the axles, how will the car get towed? It wouldn't have any parts pertaining to wheels? Would a junk yard even want it? Or could I sell it for scrap metal?
What about the transfer case? Does that ever wear out? I don't think it is compatible with mine because mine is 2WD and this one is 4WD.
#14 Guest_86 subaru_*
Guest_86 subaru_*
  • Guests
Posted 25 July 2003 - 01:10 PM
one more small thing get the clock , floor mats, sunvisors, inside door arms, dash switches,
