Seized distributor on Loyale
5 replies to this topic
#1 viceversa
viceversa
    Subaru Fanatic!
  • 368 posts
  • Virginia
Posted 18 October 2003 - 07:33 PM
92 Loyale with 1.8L
No ignition, so I took the distributor cap off and saw that the rotor doesn't turn when the engine cranks.
Bad distributor or timing chains? The latter were installed 2 months ago and are new.
#2 ByTheSea
ByTheSea
    1000+ Super USER!
  • 1,364 posts
  • Mass, USA
Posted 18 October 2003 - 07:42 PM
You should check the timing belts first. *MOTOR NOT TURNING OVER FOR SAFETY* Theres a rubber oblong inpection/slack adjuster access plug that you can remove and get a finger into to see if the belt is slack. There are two plugs. You want the one to the right of the crank pully(lowest pully in center of motor) as you look at it. Thats the most likely culprit. If the belt is good it's possible that the set screw fell out of the rotor but I'd expect it to turn at least fitfully when you crank if that were the case. If your disty actually siezed you'd hear some funky sounds when you crank as the belt jumps teeth trying to turn that frozen gear.
Brad
#3 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
If the distributor does not rotate you have one of three things. The first, and most common, is a broken timing belt, which is likely if the belt was not installed properly. The second and third, although not as common, can happen, and that is either the pin that holds the drive gear on the end of the distibutor shaft broke, or the drive gears are stripped out. You can check the belts by removing the covers, the one on the driver's side drives the distributor, so you can remove that side's cover and see if the belt is broken or not. Other possibility is a broken camshaft.
#4 Tom63050
Tom63050
    Subaru Fanatic!
  • 373 posts
  • St. Louis
Probably a broken timing belt on the driver's side. That controls the distributor too.
#5 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 October 2003 - 08:05 PM
Hey guys .. theres one more thing.. Although I agree its probably a timing belt issue, first check to make sure the little screw that holds the rotor in place is still there.. they work themselves out occasionally
#6 viceversa
viceversa
    Subaru Fanatic!
  • 368 posts
  • Virginia
Posted 19 October 2003 - 06:05 AM
I had this motor put in by a shade-tree mechanic who doesn't really know foreign cars, I think. These timing belts are new. How does one properly install them?
