Which will wear faster, my front or rear tires? if I have an LSD in the back. I'm thinking rears as they are stressed more by turning?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
tire wear vs LSD
Started by
Guest_baccaruda_*
, Jul 24 2003 11:26 PM
4 replies to this topic
#1
Guest_baccaruda_*
Posted 24 July 2003 - 11:26 PM
#2
Guest_Russ Hill_*
Posted 25 July 2003 - 10:41 AM
Hi Andy,
Your front would still wear out fastest. The LSD wont make any diff (no pun intended). The LSD carrier doesn't really do anything too special until the right wheel begins to slip. Then it bleeds power to the left wheel until the right wheel gets traction again.
Unless the right wheel is slipping it acts the same as a non-LSD rear.
#3
Guest_Konrad_*
Posted 25 July 2003 - 11:27 AM
front will wear more because of the engine in front, and steering, Russ is right, the LSD will lock only if the other wheel is spinning, so on asphalt its hard to make (in 4WD) them spin,... its possible(
),...... in off-roading the tires are slipping and it dont make too much damage to the tires because mud or grass isn't so hard,......
konrad
1989 DL Wagon 5spd D/R with LSD
1984 GL Sedan RWD
1982 DL Sedan 4WD
konrad
1984 GL Sedan RWD
1982 DL Sedan 4WD
#4
Guest_baccaruda_*
Posted 25 July 2003 - 11:47 AM
cool, thanks!
#5
Guest_McBrat_*
Posted 25 July 2003 - 12:27 PM
the clutch type LSD's from the RX's and '89 GL-10 Turbos (3.700) are "locked" until they slip at about 45 lbs of pressure. that's why when you jack the rear end up, both wheels spin the same direction...
the Viscous LSD from the 91-93 turbo legacys, and newer soobs, is open to start with, but when one side spins, as the spinning gets faster, it starts to drag the other side with it....
auto.howstuffworks.com/differential6.htm
