5-speed swap questions..
1 reply to this topic
#1 Meeky Moose
Meeky Moose
    Subaru Master
  • 2,343 posts
  • Grants Pass
Posted 15 March 2006 - 06:30 PM
just a couple..
say i found a na 3.9 ratio 5-speed for my turbo legacy..
will the na clutch hold up0 to the turbo engine? or can i use a turbo clutch and pressure plate with the na trans and flywheel? i was thinkin the splines might be different.. but i am used to working on the old ea series cars.. this is my first ej car besides the outback..
also are my turbo cv's gonne go on the na 5-speeds output shafts or are the spline counts different there too?
#2 WagonsOnly
    Now only WagonsMostly.
  • 1,475 posts
  • North Central CT
Posted 16 March 2006 - 01:41 AM
You'll be good with the clutch/pressureplate/NA tranny handling the power, someone up here took an EJ22 five-speed and mated it to an SVX with no problems. Not sure on the spline count though. Jesse (Subafreak) might know.
