Error code 35?
10 replies to this topic
#1 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 21 October 2003 - 11:46 AM
Hi All,
I have a 92 Subaru Loyale wagon, auto, 4WD and the "check engine" light has been on since I got it back.
I read the codes from the computer and it is an error code "35" which I think is the purge control valve.
What is this valve for?
Dose it affect MPG or preformance?
Where is it located?
How do I fix this?
T.J.
#2 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 21 October 2003 - 12:33 PM
the purge solinoid is for purging the vapors from the charcoal canister (can up in right front of car) folow the lines off the canister to see where the solioid is. I think its on the manifold. depending on what failed you could have diferent problems. check connections and all that but it probably is shorted out.:-\
#3 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 21 October 2003 - 10:19 PM
Everything looks fine.
How can I test the part itself?
Any other ideas?
:confused:
#4 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 21 October 2003 - 10:23 PM
there a few few tests to be done.. one is checking resistance.. when unplugged, I believe it should read out right around 35-37 ohms(someone please correct me if I'm wrong)
#5 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 22 October 2003 - 09:39 AM
EGR = 32-39 ohms
PCS = under 100 ohms
Provided by asavage via oregonloyale
#6 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 22 October 2003 - 11:33 AM
Do you want me to check the resistance on the "purge control valve"?
Is that the little metal mushroom shaped object on top of the charcoal canister?
T.J.
#7 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 22 October 2003 - 12:18 PM
yes check resistance on the solinoid. I dont think its on the canister itself but I could be wrong. there are some better tests but resistance is easyest for most people.
#8 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 27 October 2003 - 11:54 PM
I checked the resistance on the "purge control valve" and "it's dead Jim." I even took it out and applied voltage directly to see if the solinoid would "click".... no luck.
So... how hard is it to get a new one? Is thjs a dealer only item?
Will it effect gas millage & performance?
T.J.
#9 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 28 October 2003 - 04:20 PM
Any ideas?
:confused:
#10 Holmes
Holmes
    USMB is life!
  • 138 posts
  • Oakland, CA
Posted 28 October 2003 - 04:54 PM
Do a search on the web for used subaru parts. Put in a couple of email parts requests and you should be able to find one. I found a tested used one for $20, but before I got around to ordering it , my hard drive took a dump. I'm not sure what place I got the quote from. The quotes I got on used ones ranged from $20-$45 if I remember correctly.
Also, check out these threads -
http://usmb.ultimate...=&threadid=3953
http://usmb.ultimate...=purge solenoid
If you buy from the dealer, try using the part number Asavage gives in his post (Subaru Part #14774AA101). It costs almost half as much as the original listed part.:headbang:
#11 trooperjeep
trooperjeep
    USMB is life!
  • 155 posts
  • Rochester, NY
Posted 01 November 2003 - 09:02 PM
I took a 1 hour drive out to a country junk yard that has a few wrecked, old Subarus... I was able to get a Purge Control Valve off a 93 Loyale for only $15! That sure beats the dealer cost of $102!
Now my 92 Loyale's check engine light is out and the engine also seems to run a little smoother as well. Hopefully this will imporve the gas millage to.
The best part was that the junk yards "lot car" was an old 90 Loyale wagon that was tearing through the huge mud puddles and thick mud like it was nothing!
I'm glas to see they can still take a beating after all these years!
:D
T.J.
