93 Legacy, Hesitation, but only when hot?
4 replies to this topic
#1 baboonia
baboonia
    User Awaiting Email Confirmation
  • PipPipPip
  • 40 posts
  • West Coast
Posted 05 April 2006 - 05:04 PM
93 Legacy, 2.2 non-turbo. Starts up runs perfect, until it gets hot. It then boggs down and has serious hesitation.
I plan on installing new NGK plugs (not sure what it has now), replacing PCV valve and possibly the 2 wire coolant temperature sensor.
Anything else I should check/try?
#2 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 05 April 2006 - 11:40 PM
I would check the coil pact, breaking down under heat sounds like it could be the problem.
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 06 April 2006 - 11:29 AM
Definitely do the coolant temp sensor.
#4 baboonia
baboonia
  • PipPipPip
  • 40 posts
  • West Coast
Posted 10 April 2006 - 06:49 AM
It turns out that my VW fuel pump was getting weaker as it ran longer. The fuel pump was causing the problem. After replacing the fuel pump everything was happy again.
(I neglected to mention the 93 Subaru engine is installed in an 89 Vanagon)
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 10 April 2006 - 12:18 PM
Ahh....glad you figured it out.
