WJM Posted October 23, 2003 Share Posted October 23, 2003 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2438625060 edit: hey, looks like the housings are turned the wrong way... Quote Link to comment Share on other sites More sharing options...
dsmracer Posted October 23, 2003 Share Posted October 23, 2003 I don't see anything that says it's for an EA82T. Quote Link to comment Share on other sites More sharing options...
bbbs53 Posted October 23, 2003 Share Posted October 23, 2003 Says he bought it for his WRX, which would mean 2.5 litre. Then bought the STI. Someone has too much cash. Quote Link to comment Share on other sites More sharing options...
bushbasher Posted October 23, 2003 Share Posted October 23, 2003 the ea82 turbo is an rhb5 isn't it? Quote Link to comment Share on other sites More sharing options...
PHATBRAT Posted October 23, 2003 Share Posted October 23, 2003 Bradd, I thought the WRX was a turbocharged 2.0? But you are right, too much money on his hands... Quote Link to comment Share on other sites More sharing options...
pleiades Posted October 23, 2003 Share Posted October 23, 2003 The RHB5 is the VF7 or whatever that came on the Legacy Sport Sedan/Wagon (turbo legacy). Quote Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted October 23, 2003 Share Posted October 23, 2003 I can't see the serials on it, or I would tell you for sure. If you want a serious upgrade for your EA82 though, lemme tell you the secret. Take your old RHB5 off, remove in the intake side of the turbo, exposing the compressor. Now remove the compressor. Find yourself an RHB5-2 off a turbo Legacy, early 90's type. Now take off the intake side of the Leg's turbo, both the houseing and compressor, now bolt the Leg's compressor onto the 82's turbo, then put on the Leg's housing, wha Lah, you have have a turbo that puts more boost, but doesn't spool any slower. Now all you have to do is bypass that boost cut problem. Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted October 23, 2003 Share Posted October 23, 2003 Originally posted by Adam N.D.J. I can't see the serials on it, or I would tell you for sure. If you want a serious upgrade for your EA82 though, lemme tell you the secret. Take your old RHB5 off, remove in the intake side of the turbo, exposing the compressor. Now remove the compressor. Find yourself an RHB5-2 off a turbo Legacy, early 90's type. Now take off the intake side of the Leg's turbo, both the houseing and compressor, now bolt the Leg's compressor onto the 82's turbo, then put on the Leg's housing, wha Lah, you have have a turbo that puts more boost, but doesn't spool any slower. Now all you have to do is bypass that boost cut problem. and have it balanced... right?? Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 23, 2003 Share Posted October 23, 2003 I would like to know how you balance a turbo? Rob Quote Link to comment Share on other sites More sharing options...
WJM Posted October 23, 2003 Author Share Posted October 23, 2003 Its an RHB5 that came on our EA82Ts. AND, you can tell by the exhaust housing and by the overall structure of the turbo that it will bolt right up to and EA82T, IF the housings were turned right. Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted October 23, 2003 Share Posted October 23, 2003 Originally posted by Turbone I would like to know how you balance a turbo? Rob well, I dont know the exact procedure, but.. its a good idea to balance it because they do spin at 120,000 rpms + even if its just a little off, at that speed.. it could be a problem.. im sure you could get away with not doing it, but that would imact the life of your turbo's bearings.. bean Quote Link to comment Share on other sites More sharing options...
rallyruss Posted October 23, 2003 Share Posted October 23, 2003 cool . if that turbo was designed for a wrx then the exhaust side flange is slightly different than a ea82 turbo ( I tried it once). I have considered doing a wrx turbo swap. but it requires a good deal of fabrication and I need more time/money:-\ adam have you done the legacy turbo hybrid? sounds really cool. I want to know more. sounds easy enough to do. Quote Link to comment Share on other sites More sharing options...
WJM Posted October 23, 2003 Author Share Posted October 23, 2003 No, its NOT a TD04, its an RHB5 with a different compressor housing on it. The exhaust housing is IDENTICLE to ANY RHB5 on ANY EA82T, that I am sure of. But still both housings are bolted on all wrong. Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted October 24, 2003 Share Posted October 24, 2003 so - what you are saying is, the exhaust flange on the legacy turbo is the same as the ea82t, but the it points all the wrong way? .. cant you rotate the compressor housing? or is the turbo setup to sit the wrong way... Quote Link to comment Share on other sites More sharing options...
WJM Posted October 24, 2003 Author Share Posted October 24, 2003 the Legacy turbo is a VF10. The RHB5 i think is a VF7. The US WRX is a mitsu TD04, and STi's and others get VF34, and 22's. The exhaust housing on the VF10 is different than our RHB5's. The exh. housing on that turbo is origonal from the RHB5, it sjust turned the wrong way. I looks like its got a different compressor housing, and it too is turned the wrong way. Quote Link to comment Share on other sites More sharing options...
pleiades Posted October 24, 2003 Share Posted October 24, 2003 Originally posted by WJM the Legacy turbo is a VF10. The RHB5 i think is a VF7. ..... Damn, I think you're right! lol.... Quote Link to comment Share on other sites More sharing options...
WJM Posted October 24, 2003 Author Share Posted October 24, 2003 LOL I hate it when that happends! Quote Link to comment Share on other sites More sharing options...
